very fast n/a on ebay
Dave
Lying about Bhp is a truly a bad thing and I would throw him to the wolves,
He should be crucified and then dragged through the streets until his ar--se caught alight, Probably these would burn the wrong way and hurt internally
And as for being a member I will join as it seems it is neccesary to be a member to drive a Supra.
Now the big cylinder things connected to the hot pipe if I have two does that mean its a twin no idead cos I aint clever enough best I ask a member.
Have been an engineer for 20 plus years and an earlier statment in this thread proves that certain members are so far up there own bottom they cannot see the sunlight.
Others however are smart helpful and knowledgable and these I salute
Rant over had a bad two days:search::rolleyes::cool:
If you have tons of pipework, rubber hoses and cant see the turbos easily then yes you have twins. If you can see only 1 turbo then its normally the case that you have 1
Pic attached is of a typical twin setup but with aftermarket air filter
