MaRkYbOy72 Posted October 26, 2007 Share Posted October 26, 2007 Apart from the tubbies failing, what are the most expensive and common problems that Supras endure and roughly how much is it to fix them. Just curious ... Quote Link to comment Share on other sites More sharing options...
hogmaw Posted October 26, 2007 Share Posted October 26, 2007 If it's stock then nothing really. The more you mod, the more likely something will fail, esp if you go single. if anything, the most likely problem that will happen is a crash due to excess enthusiasm of the right foot. Quote Link to comment Share on other sites More sharing options...
Jake Posted October 26, 2007 Share Posted October 26, 2007 Turbos failing isn't common. Cracked rads and sheared crank pulleys are pretty common but usually not silly money to fix. (say a couple of hundred) but otherwise they are pretty reliable. You seem to be worried about maintenance costs. Running costs are the biggest issue for most of us. I say 'issue' rather than 'problem' because it's something you just accept, or not. If you can afford to run a Supra the maintenance shouldn't be a problem. Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted October 27, 2007 Share Posted October 27, 2007 Heater Matrix.. Not too common, but expensive & a real pain! Quote Link to comment Share on other sites More sharing options...
