uzthedentist Posted October 26, 2007 Share Posted October 26, 2007 Ive just blown out my crank oil seal for the 2nd time. Getting it sorted again soon. Theres no real clue as to why this is hapening. im only BPU after all. anyone know why this could be happening and any remedies to prevent it? Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 26, 2007 Share Posted October 26, 2007 Front one? Oh dear, dear dear, that'll be an expensive fix. Link to comment Share on other sites More sharing options...
uzthedentist Posted October 26, 2007 Author Share Posted October 26, 2007 i think it is yes, it was that last time, and yes was expensive. any idea how i can stop it happening? Link to comment Share on other sites More sharing options...
michael Posted October 26, 2007 Share Posted October 26, 2007 Who replaced it last time? Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 26, 2007 Share Posted October 26, 2007 Give me a potted history of the engine, what's been done to it, by whom, and when. Link to comment Share on other sites More sharing options...
uzthedentist Posted October 26, 2007 Author Share Posted October 26, 2007 whifbitz did it, theyre not sure why it might be happening. i have an oil catch can, should i remove it? Link to comment Share on other sites More sharing options...
uzthedentist Posted October 26, 2007 Author Share Posted October 26, 2007 engine has: intake, full decat exhaust with restrictor ring. fmic, walbro 255l/hr fuel pump, stock injectors, sard trigger boost controller, oil catch tank intake i fitted myself, catback exhaust fitted by local garage, decat by whifbitz, pump by whifbitz, boost controller by whifbitz. fmic and oil catch tank by turbofit(rubbish) im wondering if there may be a kink in theoil catch can feeds that is causing pressure to build up? edit all work was done no longer than 6 months ago http://www.uzmanulhaq.info/blingedybling.jpg Link to comment Share on other sites More sharing options...
Guest mugg Posted October 26, 2007 Share Posted October 26, 2007 Sorry to hear that ......alot i would say would be a poor install....Cleaning the mating surfaces of the case ..inside and out ( with a alcohol say and cotton tip to get to the section ...lip just inside the oil pump case ) is a Must !!! It's not a hard job at all .Then placement ....OEM seal .....and if your crank snout has a slight wear in the location of where the seal has been running which would require a speedy sleave .....But i can say IF you clean ALL Extremley well first ....use Only OEM seal ....lube the inside vgroove with high speed moly grease make sure only in the vgroove ....a light smear of RTV around the outside of the FMS then Placement .... For placement of the seal use a correct size piece of PVC pipe or the like as long as its correct size and long enough to make over the crank snout .... On the oil pump case it has a very slight bevell ..Place the OEM FMS with RTV smear around the outside just past this slight bevell ... it would be aprox 1.5mm back from the front of the oil pump case face .....(get a good light and look and see it first ) use the PVC to place the FMS even and flush with this bevell edge If there is any excess lightly finger smear it around the edge of the seal .....Then let it set over night . Then put it back together .....While your there ....how is your timing belt and Dampner ?? Good luck .. hope this might help and take your time ....It's not hard . Nice clean bay ......check you pcv system or breathers also Link to comment Share on other sites More sharing options...
uzthedentist Posted October 26, 2007 Author Share Posted October 26, 2007 im not doing it lol, whifbitz will do it, they do a pretty good job of things Link to comment Share on other sites More sharing options...
Guest mugg Posted October 26, 2007 Share Posted October 26, 2007 Ok no sweat .........GL with it Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 26, 2007 Share Posted October 26, 2007 New oil pump is the only fix;) Link to comment Share on other sites More sharing options...
Lee P Posted October 26, 2007 Share Posted October 26, 2007 New oil pump is the only fix;) Link to comment Share on other sites More sharing options...
Marty Posted October 26, 2007 Share Posted October 26, 2007 Nice write up Sorry to hear that ......alot i would say would be a poor install....Cleaning the mating surfaces of the case ..inside and out ( with a alcohol say and cotton tip to get to the section ...lip just inside the oil pump case ) is a Must !!! It's not a hard job at all .Then placement ....OEM seal .....and if your crank snout has a slight wear in the location of where the seal has been running which would require a speedy sleave .....But i can say IF you clean ALL Extremley well first ....use Only OEM seal ....lube the inside vgroove with high speed moly grease make sure only in the vgroove ....a light smear of RTV around the outside of the FMS then Placement .... For placement of the seal use a correct size piece of PVC pipe or the like as long as its correct size and long enough to make over the crank snout .... On the oil pump case it has a very slight bevell ..Place the OEM FMS with RTV smear around the outside just past this slight bevell ... it would be aprox 1.5mm back from the front of the oil pump case face .....(get a good light and look and see it first ) use the PVC to place the FMS even and flush with this bevell edge If there is any excess lightly finger smear it around the edge of the seal .....Then let it set over night . Then put it back together .....While your there ....how is your timing belt and Dampner ?? Good luck .. hope this might help and take your time ....It's not hard . Nice clean bay ......check you pcv system or breathers also Link to comment Share on other sites More sharing options...
JamieP Posted October 26, 2007 Share Posted October 26, 2007 New oil pump is the only fix;) Did you take the engine out when you did your oil pump bud? Link to comment Share on other sites More sharing options...
uzthedentist Posted October 26, 2007 Author Share Posted October 26, 2007 guess im gonna have to gt one Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 26, 2007 Share Posted October 26, 2007 Did you take the engine out when you did your oil pump bud? No just drooped the sub frame, well got someone else to as i was feeling lazy;) Link to comment Share on other sites More sharing options...
supradibbs Posted October 26, 2007 Share Posted October 26, 2007 well u know how many i have been through at least 4 i have decedied on a full rebuild and have gone for a new oil pump get yourself a phr pump cheaper than unmodified stock one Joe at PHR has them in stock fast delivery too!!!!!!!!!! Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 26, 2007 Share Posted October 26, 2007 well u know how many i have been through at least 4 i have decedied on a full rebuild and have gone for a new oil pump get yourself a phr pump cheaper than unmodified stock one Joe at PHR has them in stock fast delivery too!!!!!!!!!! They where about £80-100 dearer than stock when i bought one, and its only a case of enlarging the drain hole;) Link to comment Share on other sites More sharing options...
supradibbs Posted October 26, 2007 Share Posted October 26, 2007 They where about £80-100 dearer than stock when i bought one, and its only a case of enlarging the drain hole;) exchange rate there like 350 bucks Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 26, 2007 Share Posted October 26, 2007 It needs a full engine strip, a proper, total one, and all the oil galleries cleaning out, re assembling after sizing the crank and the cam bearing bores with new shells and a new oil pump. You might as well bore and re piston it whilst you're at it, and give it a head job. The pump will be goosed and the oil system full of the metallic bits from the pump. Any less of a job is a cock up. You also need to see why the pump failed, it's PROBABLY due to it running too rich for some reason, or has run cheap oil in the past. It's ABSOLUTELY nothing to do with the seal itself, or having to glue them in, blah blah. If there's a wear lip on the crank nose you will probably find it cheapest to fit another crank, IMO. Link to comment Share on other sites More sharing options...
Stevie Boy Posted October 26, 2007 Share Posted October 26, 2007 It needs a full engine strip, a proper, total one, and all the oil galleries cleaning out, re assembling after sizing the crank and the cam bearing bores with new shells and a new oil pump. You might as well bore and re piston it whilst you're at it, and give it a head job. The pump will be goosed and the oil system full of the metallic bits from the pump. Any less of a job is a cock up. You also need to see why the pump failed, it's PROBABLY due to it running too rich for some reason, or has run cheap oil in the past. It's ABSOLUTELY nothing to do with the seal itself, or having to glue them in, blah blah. If there's a wear lip on the crank nose you will probably find it cheapest to fit another crank, IMO. Ouch! Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 26, 2007 Share Posted October 26, 2007 One mans "ouch" is another mans next exotic animal or tractor implement.... Or more likely overdraft repayment Link to comment Share on other sites More sharing options...
Stevie Boy Posted October 26, 2007 Share Posted October 26, 2007 One mans "ouch" is another mans next exotic animal or tractor implement.... Or more likely overdraft repayment The latter was more along the lines i was thinkin........ Link to comment Share on other sites More sharing options...
RedM Posted October 26, 2007 Share Posted October 26, 2007 It needs a full engine strip, a proper, total one, and all the oil galleries cleaning out, re assembling after sizing the crank and the cam bearing bores with new shells and a new oil pump. You might as well bore and re piston it whilst you're at it, and give it a head job. The pump will be goosed and the oil system full of the metallic bits from the pump. Any less of a job is a cock up. You also need to see why the pump failed, it's PROBABLY due to it running too rich for some reason, or has run cheap oil in the past. It's ABSOLUTELY nothing to do with the seal itself, or having to glue them in, blah blah. If there's a wear lip on the crank nose you will probably find it cheapest to fit another crank, IMO. All this from the man who will be having a look at my oil leak in a few weeks. I shudder at what the verdict might be. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 26, 2007 Share Posted October 26, 2007 I will add that in my case there where no metal (well alloy as thats the part that wears in the pump) particles in my sump whatsoever, there could have been very very fine alloy dust suspended in the oil, but i also suspect that my engine had been apart before in an effort to rectify the seal leak by opening out the pump drain, which will still not compensate for a worn pump, and it only takes a bit of scoring on the pump spigot for it to leak like a sieve. Link to comment Share on other sites More sharing options...
