Terminator Posted June 23, 2002 Share Posted June 23, 2002 Awkward little bugger isn't it!!! It tried to get it out last night (cold) but the hoses just don't want to come off. Or do I have to get physical, I don't want to bust anything. Any tips for easy removal would be appreciated. Quote Link to comment Share on other sites More sharing options...
Barry Posted June 23, 2002 Share Posted June 23, 2002 Stanley knife.! or move the clips, get some grippers and twist the pipes until they brake loose. Its all on quite tight so a bit of force is required. I keep meaning to do mine but need to find something to block the hoses off with. What are you going to use?? Quote Link to comment Share on other sites More sharing options...
Terminator Posted June 23, 2002 Author Share Posted June 23, 2002 Originally posted by Barry Stanley knife.! What are you going to use?? I am just removing it to put another one on, to check its works for someone else on the BBS, they need all the hoses, so the Stanley knife option is out. I will be using rubber blanks, when it stays off. Quote Link to comment Share on other sites More sharing options...
Nic Posted June 23, 2002 Share Posted June 23, 2002 Phil When I watch the garage fit mine they used a silicon lubricant spray to help get the hoses off/on. They used a flated headed screw driver to lever one edge of the hose open a little, then sprayed some of the lubricant in. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted June 23, 2002 Share Posted June 23, 2002 As Barry says, use some pliers to twist the pipe and break the seal first. If still stiff you can use an appropriate size spanner to push the pipe off. Quote Link to comment Share on other sites More sharing options...
Terminator Posted June 23, 2002 Author Share Posted June 23, 2002 Thanks for the help guys. All done just a twist and they were not too bad to get off. I was just worried about splitting a hose. Quote Link to comment Share on other sites More sharing options...
