EVO9 Brembo big brake kit
JamieP
I used these calipers and fitted them to UK spec disks. Works a treat... (needs engineered brackets to fit which my mate can supply) Reasonable price! Good luck Jamie
how much for the brackets to be made, how do the compare to running uk spec calipers, does it work out much cheaper then just buying the uk set up brakes?
You'd have to get in touch with him as it'd be private work. PM me and I'll give you his details. I don't want to get into any trouble for posting this on here.
This topic has been bounced around for a while, and I figured I'd just go for the Brembo's based on weight as the general consensus was that the diametre of the disks had not changed, therefore the stopping power should be roughly the same, as there are still 4 pistons (simplified version - use the search facility for the full article).
The Brembo's weighed in at under a kilo each and the stock J-spec ones were 2.5kg's each, so I'd assume that the UK spec ones will be closer to 3kg's each.
Good luck :)
