Scott Posted February 16, 2012 Share Posted February 16, 2012 thinking out loud but can you not just put the battery in the other way around , if the negative terminal is nearest the wing, do a 180 with the unit , negative terminal is furthest away from the wing Maybe I am missing something; my battery is in the boot I did give that a go with my previous battery, there wasn't enough length for the positive to stretch over to the rhs though. In the end I just extended the cables with some fresh stuff, looked a lot better. Link to comment Share on other sites More sharing options...
Scott Posted February 16, 2012 Share Posted February 16, 2012 How do I stop my positive terminal from popping off?! It did it again today, and messed everything up. The actual terminal itself or the clamp? If it's the terminal then I would replace the battery as that doesn't sound right at all. If it's the clamp then it sounds like it's the wrong size for the battery. Link to comment Share on other sites More sharing options...
Jellybean Posted February 16, 2012 Share Posted February 16, 2012 I did give that a go with my previous battery, there wasn't enough length for the positive to stretch over to the rhs though. In the end I just extended the cables with some fresh stuff, looked a lot better. Got cha Link to comment Share on other sites More sharing options...
AndrewOW Posted February 16, 2012 Share Posted February 16, 2012 The actual terminal itself or the clamp? If it's the terminal then I would replace the battery as that doesn't sound right at all. If it's the clamp then it sounds like it's the wrong size for the battery. The clamp is the right size for the terminal, but over time it loosens and pops off, much to my delight. I retorque it tight, but when it goes, it's kinda just hanging there. Should I renew the clamp, perhaps? An easy job? Link to comment Share on other sites More sharing options...
Scott Posted February 16, 2012 Share Posted February 16, 2012 The clamp is the right size for the terminal, but over time it loosens and pops off, much to my delight. I retorque it tight, but when it goes, it's kinda just hanging there. Should I renew the clamp, perhaps? An easy job? If it's the right size and it's properly tightened then it wouldn't be able to loosen. It sounds like it's barely getting any bite on the terminal at all and loosening off with vibration. I would definitely look to get a new terminal but I would suggest that it's definitely not the right size on there currently. Link to comment Share on other sites More sharing options...
caseys Posted February 17, 2012 Share Posted February 17, 2012 Random Supra general knowledge quiz - Does anyone know the battery tray dimensions or the WxDxH (and weight) that the area where the battery goes will support without modification? Link to comment Share on other sites More sharing options...
caseys Posted March 5, 2012 Share Posted March 5, 2012 Gone for this battery in the end http://www.tayna.co.uk/Exide-EP450-DUAL-AGM-Battery-Maxxima-MAX900DC-P7502.html http://www.tayna.co.uk/Exide-EP450-DUAL-AGM-Battery-Maxxima-MAX900DC-Reviews-7502.html Cheaper than the Optima Yellowtop (£193 for the Optima, £162 for the Exide) if you hunt around, no problems fitting size wise, 750CCA and it's a 6-cell sealed unit, even has bolt on terminals which I will be switching to when I find an evening to rewire, also as it's 6 circular cells it's got mounting holes through the middle so you can bolt it down or even mount it sideways or upside down if you so desire. Highly highly recommended, car cranks a lot better and car stays running at a higher voltage than my crappy old Yuasa. Link to comment Share on other sites More sharing options...
Dan_Turism0 Posted March 5, 2012 Share Posted March 5, 2012 apologies if this has already been covered but is there a battery that fits in the cubby-hole in the boot of the supra under the carpet flap behind the rear seats? Link to comment Share on other sites More sharing options...
Jellybean Posted March 6, 2012 Share Posted March 6, 2012 apologies if this has already been covered but is there a battery that fits in the cubby-hole in the boot of the supra under the carpet flap behind the rear seats? My battery fits in there snug, Optima Length: 254 mm Width: 174 mm Height: 200 mm Link to comment Share on other sites More sharing options...
loks Posted August 12, 2012 Share Posted August 12, 2012 Some more infor from Mr T... maybe of help to some? http://www.toyota.com/toyota-owners-online-theme/pdf/Batteries2011-LowRes.pdf Link to comment Share on other sites More sharing options...
Nikue Posted November 17, 2012 Share Posted November 17, 2012 Can someone advise about whether the battery in my Supra will do or I should look for another. The standard battery spec according to a battery on line buying site is CCA 500 (kick over power) Amphere hours 60 (constant power) The one I have is 540 and 55 . CCA is fine but the Amphere hours is less. Does this mean the alternator will have to work harder or is it splitting hairs and the battery will do? Cheers Link to comment Share on other sites More sharing options...
Sharpie Posted November 18, 2012 Share Posted November 18, 2012 Well I bought my HCB005 in 2004, had it replaced in 2006 FOC and now it's on it's last leggs really (not bad 7yrs for the price of £55)so, going back to a Toyota one which, is a £24 saving over the price of the Halfords one these days and does come with a 3yr G-tee. I used the original part number of: T28800-YZZAE on my UK spec, from the one I bought in 2002 and it's still valid. £59 + VAT pickup on Saturday I had to take my Toyota battery back last week as it would not hold a charge over 11v but, they swapped it right out Link to comment Share on other sites More sharing options...
Digsy Posted November 26, 2012 Share Posted November 26, 2012 Just thought I would bump this as at the weekend I changed my stock Toyota battery after two years under Toyota's three year warranty. No quibbles at all, just a quick test and I walked out with a new battery Link to comment Share on other sites More sharing options...
Sheefa Posted June 18, 2013 Share Posted June 18, 2013 Just thought I would bump this as at the weekend I changed my stock Toyota battery after two years under Toyota's three year warranty. No quibbles at all, just a quick test and I walked out with a new battery Thread bump as I did the same, great battery the Halfords HCB005 Link to comment Share on other sites More sharing options...
Scott Posted June 18, 2013 Share Posted June 18, 2013 Thread bump as I did the same, great battery the Halfords HCB005 You got a halfords battery from Toyota under warranty? That's impressive Link to comment Share on other sites More sharing options...
ghostbuster Posted July 29, 2013 Share Posted July 29, 2013 Halfords price now is £94.99 as of july 2013:taped: Link to comment Share on other sites More sharing options...
skippyboyo1 Posted May 26, 2014 Share Posted May 26, 2014 Good thread this! Link to comment Share on other sites More sharing options...
Mcdade Posted March 23, 2015 Share Posted March 23, 2015 Can anyone tell me does the hcb005 sit ok with the stock battery clamp?? Link to comment Share on other sites More sharing options...
downimpact Posted March 24, 2015 Share Posted March 24, 2015 Can anyone tell me does the hcb005 sit ok with the stock battery clamp?? Did with mine, can always put something on the tray to boost if needed. Link to comment Share on other sites More sharing options...
Marty Posted March 24, 2015 Share Posted March 24, 2015 Can anyone tell me does the hcb005 sit ok with the stock battery clamp?? Didn't with mine. It was too big height wise. Link to comment Share on other sites More sharing options...
Kendo11 Posted March 24, 2015 Share Posted March 24, 2015 Weird, fit perfectly with mine Link to comment Share on other sites More sharing options...
Alex Posted March 25, 2015 Share Posted March 25, 2015 Didn't with mine. It was too big height wise. Then either your battery tray isn't right or the battery isn't in it correctly or you don't have an HCB005. It definitely fits. Link to comment Share on other sites More sharing options...
Westy Posted April 1, 2015 Share Posted April 1, 2015 Just picked up a new HCB005 for my black car. Currently £79.99 Old one has given up the ghost Link to comment Share on other sites More sharing options...
V Posted August 25, 2015 Share Posted August 25, 2015 From my post #65, mines died. Struggled to find another one off the shelf easily. But got a Duracell Advance DA45 with 5yr warranty. My battery is the much smaller Type 156 with T3 small terminals. Eurocar parts £55 inc VAT. Link to comment Share on other sites More sharing options...
mwilkinson Posted August 25, 2015 Share Posted August 25, 2015 Also got a HCB005 from local Halfords. £79.99. I need to get a UK Spec battery clamp now. Link to comment Share on other sites More sharing options...
