MattyB Posted December 16, 2008 Share Posted December 16, 2008 Having had a tired old jap battery in my 11 year old Supe, (it really looks like the original, but surely cant be, no signs of any tampering with the clamp screws???) I then spent a couple of wasted trips to Halfrauds, followed by a fair few hours researching on here and Googling batteries I ventured to my local independent garage. My old Jap battery was the smaller version, and the terminal posts the thin type - a double whammy for trying to get a simple replacement. The battery clamp looked like a modification might be required too - triple whammy However, my replacement was a Bosch battery (an S4 004) with an ETN reference of 560 409 054. To those who have needed to research, this means it has a capacity of 60ah and a Cold Cranking performance of 540 amps, which is just above the Halfords HCB005 battery. I did find an S5 004 or S5 005 would have had a higher rating, but cost about £15 more. The S4 005 and S5 005 are slightly taller batteries, and I didnt get to find out if they would have fitted under the battery clamp or not. I have a sneaking suspicion that they would, as the original clamp that has been refitted looks as though it is tightened a little more than previously. I chose (needed!) to do have the battery terminal connectors replaced too, so that for any future battery change meant I could easily put a UK battery in, as the terminal posts are thicker than the Jap battery terminal clamps would safely allow. The best bit though was that the battery clamp did not need to be modified, (or smashed about!) - it was a miracle that the handle on the top of the battery allowed enough space for the clamp edges to sit perfectly Cost of battery was £86, replacement connectors (soldered and fitted neatly) £7, and half an hour's labour at the garage (£26). Obviously a bit more than a bog-standard battery change, but at least it looks neater, and will not be the major headache should I need a battery replaced again - I've had Bosch in the past, and only ever put them into cars I've bought, never needed to take one back nor get it renewed. Fingers crossed that they are still good - or better Link to comment Share on other sites More sharing options...
alex2jz Posted January 17, 2009 Share Posted January 17, 2009 Anybody know where i could find original Jap Spec battery connectors in case i've ditched mine? Link to comment Share on other sites More sharing options...
Wez Posted January 24, 2010 Share Posted January 24, 2010 This is the replacement Yuasa battery I used on my NA auto, I got mine from AllParts and didnt require the terminals to changed Link to comment Share on other sites More sharing options...
Guest MoeBlunt Posted January 24, 2010 Share Posted January 24, 2010 Just put a Bosch S4 battery for £60 in my J-Spec...Works a treat! Link to comment Share on other sites More sharing options...
Paul Posted January 24, 2010 Share Posted January 24, 2010 Just put a Bosch S4 battery for £60 in my J-Spec...Works a treat! Got a Bosch in the Supra and the Mazda, great batteries (made by Varta BTW, badged up as Bosch, I think it's the Varta Asian so designed for jap cars) Link to comment Share on other sites More sharing options...
Guest MoeBlunt Posted January 24, 2010 Share Posted January 24, 2010 Yup, they are Jap batteries... Link to comment Share on other sites More sharing options...
stevie_b Posted February 2, 2010 Share Posted February 2, 2010 This is the replacement Yuasa battery I used on my NA auto, I got mine from AllParts and didnt require the terminals to changed http://www.mkivsupra.net/vbb/attachment.php?attachmentid=104145&d=1264355621 It's battery replacement time for me. Wez, does that battery say "260 cold crank amps" on it? I must be mis-reading it because that sounds very low. Link to comment Share on other sites More sharing options...
Wez Posted February 2, 2010 Share Posted February 2, 2010 It's battery replacement time for me. Wez, does that battery say "260 cold crank amps" on it? I must be mis-reading it because that sounds very low. Not sure I can check later but I think its all Jap writing from memory. Suprisingly the 2JZ-GTE doesnt require that much to crank it over, my single runs a Valery RedTop 25 Link to comment Share on other sites More sharing options...
stevie_b Posted February 2, 2010 Share Posted February 2, 2010 The TT possibly takes less juice to crank it over than the NA (due to the NA being a higher compression engine). Link to comment Share on other sites More sharing options...
stevie_b Posted February 22, 2010 Share Posted February 22, 2010 I've just bought a battery from Performance Batteries. I'm impressed with their service and the new battery fits with no problems. I bought an Alphaline (I've never heard of them, but it's guaranteed for 4 years so worth a punt) 525 amp lead-calcium battery for £55 delivered. They also do a 540 amp Varta for £72 delivered. Link to comment Share on other sites More sharing options...
Digsy Posted May 17, 2010 Share Posted May 17, 2010 Don't write off Mr. T for a replacement battery. After ringing around today I got part number T28800-YZZJA (aka 28800-42030) for £51.01. That was with a 15% discount but its still a reasonably priced battery. CCA is 560A The battery they got out of stores first was the same height and width but the length was slightly more so they went away and came back with one with dimensions exactly the same as Halfords' HCB005. However when I fitted it I noticed that the battery tray is about 1/2" longer than the battery so I'm wondering if the first battery they brought out would have fitted after all. For reference that one had a CCA of 620A. Link to comment Share on other sites More sharing options...
Jay_vr6 Posted May 17, 2010 Share Posted May 17, 2010 I got one from toyota 2 weeks ago, T28800-YZZJC for £65 inc vat, the battery is huge and fits perfectly, cranks at 620a Link to comment Share on other sites More sharing options...
Digsy Posted May 18, 2010 Share Posted May 18, 2010 I got one from toyota 2 weeks ago, T28800-YZZJC for £65 inc vat, the battery is huge and fits perfectly, cranks at 620a Yep, that sounds like the one I was offered initially. Looks like I've bought the wrong one, even though it was excatly the same size as the Halfords HCB005! Link to comment Share on other sites More sharing options...
Kirk Posted September 14, 2010 Share Posted September 14, 2010 Did you have to change the terminals for the battery from toyota as im thinking of picking one up tomorrow Link to comment Share on other sites More sharing options...
Wez Posted September 14, 2010 Share Posted September 14, 2010 Did you have to change the terminals for the battery from toyota as im thinking of picking one up tomorrow If you have a jspec with the original small jspec terminals and purchase a UK battery from Halfords you will need to change the terminals, this is why I went for a replacement Yuasa available from All Parts Link to comment Share on other sites More sharing options...
Kirk Posted September 14, 2010 Share Posted September 14, 2010 And where do you aquire new terminals from? Link to comment Share on other sites More sharing options...
Kazuma Posted September 15, 2010 Share Posted September 15, 2010 Strangely enough, I need a new battery like rest of you. I had looked at Halfords but the HCB005 is now £89.99, not sure I want to pay that much! I'm gonna ring Mr T and see what they offer and how much is the pain. Link to comment Share on other sites More sharing options...
stevie_b Posted September 15, 2010 Share Posted September 15, 2010 Strangely enough, I need a new battery like rest of you. I had looked at Halfords but the HCB005 is now £89.99, not sure I want to pay that much! I'm gonna ring Mr T and see what they offer and how much is the pain. Halfords is overpriced IMO. I'm still shocked that they're usually the only show in town at what they do (i.e. big-shop-format motor spares). There's motor factors of course: fine for the likes of us but their trade-counter style probably puts off a lot of car non-enthusiasts. Link to comment Share on other sites More sharing options...
Digsy Posted September 15, 2010 Share Posted September 15, 2010 I never had to change my terminals. Link to comment Share on other sites More sharing options...
Kazuma Posted September 16, 2010 Share Posted September 16, 2010 Called Mr T yesterday and it will cost £55 if i recall. That is much better than £90, though this one will not be a calcium battery. Link to comment Share on other sites More sharing options...
Kazuma Posted September 17, 2010 Share Posted September 17, 2010 I picked up the battery today and it cost, £55 ex VAT, with VAT it was £64.71 Link to comment Share on other sites More sharing options...
Kirk Posted September 18, 2010 Share Posted September 18, 2010 Picked up the battery from toyota this morning, £55 all in and the terminals look the right size for J spec cars. Link to comment Share on other sites More sharing options...
madwoody1 Posted September 19, 2010 Share Posted September 19, 2010 going to go get one for my car tomorrow or at least this week along with coolant, rad cap and auto knob Link to comment Share on other sites More sharing options...
TopgunTT Posted September 19, 2010 Share Posted September 19, 2010 Picked up the battery from toyota this morning, £55 all in and the terminals look the right size for J spec cars. Good price, I think my red top was around £160. Link to comment Share on other sites More sharing options...
dangerous brain Posted June 2, 2011 Share Posted June 2, 2011 Time to bump this thread a bit.. Has anyone any recent experience of where to get a decent battery from at a decent price? Mine is deadsville Tennessee Link to comment Share on other sites More sharing options...
