B/C playin games
ADD
Right this is strange, with my b/c OFF im hitting 1.4 bar but on setting number 1 = 1.2bar, setting number 2 = 1.3bar and number 4 = 1.45......so what im confused about is, i thought with the controller OFF the car will run stock boost (in this case 1.4) so how comes the b/c is lower boost with different settings, i didnt think that was possible?????
any help would be appreciated
ad
Usually the fitting of a boost controller means intercepting and blocking off a couple of pipes to and from the wastegate actuator. That means the stock setup isn't working as it should be and in fact is still bypassed - the boost controller itself is still doing the job so it will probably behave oddly compared to stock.
-Ian
