N/A ECU (pre facelift)
GLENN STONEHAM
BUMP.
Got the part No off my ECU which is 89661-14600
also says 175700-4762 12v
2JZ-GE A/T
In case any traders/ breakers on here not seen this post, any suggestions who i might contact.
The ECU is needed because present one may be a/f.
If I could borrow one to check if mine is at fault (got bad over fuelling/ error code mode not performing) then that would help confirm or eliminate ECU from the equasion.
