Going single: How to block water feeds?
Sean1933
Right, im in the process of doin my single conversion and this has been bothering me for a while. Im sure the answer is simple and i will feel silly heyho! I know how to plug the water return connectors, worst case i can just join them together with a bit of waterpipe (im going to tap them though).
But how do you block the water feed lines/nipples, one comes straight out the pump and the other is right by where the heater matrix pipe connects......HELP!
  • 4 months later...
IIRC most how to's suggest to put a tight fitting bolt up inside and then put a jubilee clip over that.
Alternatively a proper 'bung' would work
Just for future reference, I done the above (look at my picture) and it still leaked as the water was running down the thread of the bolt. In the end I used a coach bolt which never had any thread towards the top of the bolt.
