Suup Posted October 22, 2007 Share Posted October 22, 2007 How to loosen this bolt: http://www.j-spec.nl/gallery/supra/171007_2jzge_demontage/11.jpg Is it clockwise or counterclockwise? Wrecked a couple wrenches and sockets, still stuck.... Open options: -Warming the bold -Using MASSIVE air tool (And yes, i will not mess up the timing......) Link to comment Share on other sites More sharing options...
Ian C Posted October 22, 2007 Share Posted October 22, 2007 It's a normal thread so counterclockwise to undo it. Big airgun yes, heat is a definite NO, as the heat wrecks the rubberised part of the pulley. Do a search on "Crank pulley bolt" and you should get some hits on how other people have managed it. Scaffold pole, starter motor trick etc etc. -Ian Link to comment Share on other sites More sharing options...
markssupra Posted October 22, 2007 Share Posted October 22, 2007 I made a tool for locking the crank pulley, it was so much easier. Link to comment Share on other sites More sharing options...
DannoSupra Posted October 22, 2007 Share Posted October 22, 2007 Breaker bar on the socket and against the chassis leg, and turn the key! Link to comment Share on other sites More sharing options...
