Broken radiator neck outlet to expansion tank
hadyn
Help!! My father unfortunately has managed to break off the expansion tank outlet plastic bit on the rad neck that the rubber pipe attaches to that goes to the expansion tank :(
Ive managed to put a smaller diameter metal pipe into the hole that runs into the rad neck. Ive secured this and fed it into the expansion tank hose.
Will this work OK? Will it be safe? Any ideas?
