hadyn Posted October 21, 2007 Share Posted October 21, 2007 Help!! My father unfortunately has managed to break off the expansion tank outlet plastic bit on the rad neck that the rubber pipe attaches to that goes to the expansion tank Ive managed to put a smaller diameter metal pipe into the hole that runs into the rad neck. Ive secured this and fed it into the expansion tank hose. Will this work OK? Will it be safe? Any ideas? Quote Link to comment Share on other sites More sharing options...
hadyn Posted October 21, 2007 Author Share Posted October 21, 2007 Also is it possible to safely superglue the broken outlet pipe on? Quote Link to comment Share on other sites More sharing options...
colsoop Posted October 21, 2007 Share Posted October 21, 2007 You might be able to get away with an epoxy resin but i would keep a real close eye on it. And look in to getting a replacement. Quote Link to comment Share on other sites More sharing options...
hadyn Posted October 21, 2007 Author Share Posted October 21, 2007 Just bought some metal epoxy stuff. Resists temps upto 150 degrees. That should do the job shouldnt it? Quote Link to comment Share on other sites More sharing options...
keron Posted October 21, 2007 Share Posted October 21, 2007 i have a manual rad for sale....nearly new, with the rad fan and an after market rad cap....£80... Quote Link to comment Share on other sites More sharing options...
