Air/Fuel ratio - should I be concerned?
Jake
I've been on the Surrey Rolling Road Day today and I'm a bit concerned about the A/F ratio printout I got. It seems to show figures of:
11.0 at 3100 rpm (0.7 bar) falling to
10.0 at 3800 rpm (0.6 bar) then pretty much staying at
10.00 all the way 8000rpm (1.0 bar, very slight AFR blip at about 4000rpm)
Apart from the fact that I'm not exactly thrilled about them revving the arse off my car (chart seems to indicate 8000rpm :eek: ) these AFR figure seem very rich don't they? I'm not convinced they're accurate but I'm not sure how to check it.
Any thoughts?
Thanks
Guest slow dog
the little blip will be were the map changes for the second turbo
and when they rolling road your car thats what they do they rev your car they cant do it on idle mate come on
Hi Paul
Yeah, I assumed it was due to that, I was more concerned about it running rich.
:D yeah I suppose you're right. 8000rpm is rather more than I usually rev it though. I don't think it's ever done 7000rpm before. (Apart from that time at Santa Pod when I forgot it was in MANU mode and revved the arse off it in first )
http://www.mpaconsultancy.co.uk/iamstupid.gif
Originally posted by Jake
Hi Paul
http://www.mpaconsultancy.co.uk/iamstupid.gif [/b]
Dont see how it hit 8000rpm dude unless you have an aftermarket ECU ;)
Dude:flame Dev
any chance you can scan the chart and e mail me it please
paulkent4 at hotmail . com
Better still, post up the dyno plots :)
Your afr does sound a bit rich, but that combined with the fact you appear to have no rev limit, sounds remarkably like the ECU I have in my car!
My car, with the stock turbo's had an AFR of 10.4 at 6500rpm at 1.3 bar!!! - Unless I'd seen it, I wouldn't have though it was possible :conf:
Still, easy way to lean it off.... Turn the boost up! :innocent:
