Guest cooljam Posted October 18, 2007 Share Posted October 18, 2007 I'm in the process of going bpu with my standard TT and have just had a front mounted intercooler fitted. Looks great, and will cope with 800bhp. Only problem is that when the turbos used to kick in and everything went backwards rapidly, now doesn't happen! At 4000rpm+ its like I've lost a ton of power. The garage that fitted it said that this is due to the turbo lag created by the massive intercooler. Has anyone heard of this before? Or am I being fed a line? Link to comment Share on other sites More sharing options...
RobSheffield Posted October 18, 2007 Share Posted October 18, 2007 What intercooler is it? AFAIK, from the very largest to smallest intercoolers, the lag is un-noticable Link to comment Share on other sites More sharing options...
Guest cooljam Posted October 18, 2007 Share Posted October 18, 2007 Thansk for the quick reply It's from a company called XS power, looks great quality. All stainless. Take a look at this link http://www.xs-power.co.uk/index.php?main_page=product_info&cPath=25&products_id=296 Link to comment Share on other sites More sharing options...
b_have Posted October 18, 2007 Share Posted October 18, 2007 Hope the intercooler isn't stainless! Probably a boost leak from a coupler. Which garage fitted it? Link to comment Share on other sites More sharing options...
Jake Posted October 18, 2007 Share Posted October 18, 2007 The garage that fitted it said that this is due to the turbo lag created by the massive intercooler. Has anyone heard of this before? Or am I being fed a line? Yes you are being Mr Spears At 4000rpm your engine is consuming 100 Ltrs of air per second 3.0Ltrs x (4000rpm/2) /60secs I don't think a few extra litres of intercooler capacity is going to make a noticeable difference. Do you? What make and model is this massive intercooler of yours? Maybe somebody else here has one almost as huge as yours. Link to comment Share on other sites More sharing options...
Jake Posted October 18, 2007 Share Posted October 18, 2007 It's from a company called XS power, looks great quality. All stainless. Take a look at this link http://www.xs-power.co.uk/index.php?main_page=product_info&cPath=25&products_id=296 Link to comment Share on other sites More sharing options...
RobSheffield Posted October 18, 2007 Share Posted October 18, 2007 XS power That will be why.... Link to comment Share on other sites More sharing options...
b_have Posted October 18, 2007 Share Posted October 18, 2007 Yes you are being Mr Spears At 4000rpm your engine is consuming 100 Ltrs of air per second 3.0Ltrs x (4000rpm/2) /60secs I don't think a few extra litres of intercooler capacity is going to make a noticeable difference. Do you? QUOTE] VE 100%?? Link to comment Share on other sites More sharing options...
Jake Posted October 18, 2007 Share Posted October 18, 2007 Hardly. I was keeping it simple. Link to comment Share on other sites More sharing options...
Guest cooljam Posted October 18, 2007 Share Posted October 18, 2007 Thanks for the advice so far guys. So the theory thus far is a leak in the new intercooler system? Link to comment Share on other sites More sharing options...
Bob Posted October 18, 2007 Share Posted October 18, 2007 You shouldn't see any losses with the fmic in place, I certainly didn't with mine and that was an ebay special. I would say that the garage who fitted it are talking bollocks, and have probably knocked a few hoses / sensors / connections when they were fitting it. Link to comment Share on other sites More sharing options...
Guest cooljam Posted October 18, 2007 Share Posted October 18, 2007 Thanks Bob. Glad to see someone thinking the same way I am! Link to comment Share on other sites More sharing options...
Ian C Posted October 19, 2007 Share Posted October 19, 2007 Either your second turbo isn't coming in, check the FAQs for sequential system problems, or your XS power intercooler can hold air in like a sponge - which has been known to be the case before. -Ian Link to comment Share on other sites More sharing options...
Ian C Posted October 19, 2007 Share Posted October 19, 2007 http://www.mkivsupra.net/vbb/showthread.php?t=35926 http://www.mkivsupra.net/vbb/showthread.php?t=35924 Link to comment Share on other sites More sharing options...
Digsy Posted October 19, 2007 Share Posted October 19, 2007 Yes you are being Mr Spears At 4000rpm your engine is consuming 100 Ltrs of air per second 3.0Ltrs x (4000rpm/2) /60secs I don't think a few extra litres of intercooler capacity is going to make a noticeable difference. Do you? QUOTE] VE 100%?? Depends where you measure it. As far as the cylinder are concerned it'll be consuming 100 litres per second at whatever pressure. At the airbox it'll be lots more litres at atmospheric pressure. At the intercooler the flow will be somewhere in between. Link to comment Share on other sites More sharing options...
Kranz Posted October 19, 2007 Share Posted October 19, 2007 Do you have a boost guage? What boost are you at full throttle before 4000 rpm and after? I'm guessing that the second turbo isn't boosting, probably caused by a hose coming off an actuator. Link to comment Share on other sites More sharing options...
TRD3000GT Posted October 19, 2007 Share Posted October 19, 2007 Either its a coupling not put on properly and probably leaking under pressure or its the fact its an XS power intercooler. You get what you pay for and the XS units are not known for quality, plenty of people run them but have nothing to compare a good Greddy or Blits or HKS unit with. Arc also make very good intercoolers. Link to comment Share on other sites More sharing options...
jim_supra Posted October 19, 2007 Share Posted October 19, 2007 Has anyone heard of this before? Or am I being fed a line? Yes you are being Mr Spears Very good:) Link to comment Share on other sites More sharing options...
dwayne Posted October 19, 2007 Share Posted October 19, 2007 where abouts in dorset are you. if you are close to me i'll try and help you figure it out bud. Link to comment Share on other sites More sharing options...
RedM Posted October 19, 2007 Share Posted October 19, 2007 Should they be called In-XS? Link to comment Share on other sites More sharing options...
DannoSupra Posted October 19, 2007 Share Posted October 19, 2007 I know the problem... XS POWER Link to comment Share on other sites More sharing options...
paul mac Posted October 19, 2007 Share Posted October 19, 2007 dont listen to all the doom mongers mate unless your intercooler has a HUGE hole in it somewhere, regardless of the quality it will boost exactly the same as any vastly overpriced item with HKS, BLITZ on the front, it sounds very much like you have a hose off, until you sort this be very carefull driving the car as it will now be sucking in unfiltered air, grit, stones, buttends, etc Link to comment Share on other sites More sharing options...
hadyn Posted October 19, 2007 Share Posted October 19, 2007 Sounds like a loose hose to me. Check all your boost pipework... Link to comment Share on other sites More sharing options...
Guest cooljam Posted October 19, 2007 Share Posted October 19, 2007 Thanks for the offer Dwayne. I might take you up on that. I'm in wimborne. Link to comment Share on other sites More sharing options...
Guest cooljam Posted October 19, 2007 Share Posted October 19, 2007 Thanks to everyone for your suggestions, especially K14 (I'll check the actuator), Ian C for the links and Paul Mac for supporting the people that can't always afford to buy Blitz! Power to eBay! Link to comment Share on other sites More sharing options...
