Fitting a GReddy PRofec B-spec
SIMON LC
Supposing that i have go with the TTC mod how it will be the fitting ??
shall the pipe that going to the actuator (in the greddy manual) by using 3 way fitting to connect one to the valve unit and the others to the 1st turbo's actuator and 2nd turbo's actuator ? ? ?
There is only one wastegate & wastegate actuator on the TT system, the others are for pre-spooling and other gubbins. The solenoid controls the boost by controlling the wastegate, so the connection will be the same as if you had it in sequential mode.
The wastegate is what controls the boost, the others are merely for pre-spooling and stuff. If your car is in TTC then the pre-spooling bits will be permanently open/closed (whichever) anyway, hence no reason to attach the solenoid to them.
Sooooooo, attach it to only the wastegate actuator in order to control the boost. :)
