Viper008 Posted June 20, 2002 Share Posted June 20, 2002 Hi All Tech help needed please. I have a Jspec TT auto and have the offer of a Gretag 6 Speed manual. Is it possible to convert the transmission from the auto and if so how do you go about it. R.G.D.S. Simon Quote Link to comment Share on other sites More sharing options...
Branners Posted June 20, 2002 Share Posted June 20, 2002 It can be done, but you will also need to change the ECU as well as probably changing the prop shaft and possibly a few other things (the manual gearbox cars have a small shock absorber type thing on the front of the engine for some reason..). Its not a cheap mod as you will probably need to run the whole ECU loom again. JB Quote Link to comment Share on other sites More sharing options...
eyefi Posted June 20, 2002 Share Posted June 20, 2002 final drive ratio is different as well. Quote Link to comment Share on other sites More sharing options...
Terminator Posted June 20, 2002 Share Posted June 20, 2002 The front shock absorber 'thingy' is the belt tensioner I believe. Quote Link to comment Share on other sites More sharing options...
