Ngk Bcpr7es
Epic
Right, been looking in the BPU Section and it says these are good to get... now my local says i can have 6 for £11 total!!! now will i notice any difference what so eva, or is it more a peace of mind to say i got better plugs
make sure they aint copper ones as apparently they will NOT do your car any good running bpu :)
Huh? I've been using exactly those plugs for the last 3 years: both on my BPU and Single Turbo.
They are copper and they're fine.
Same here jake, been using them for years at stock, BPU and single. They're fine but need to be chnaged more often on the single.
fair enough fellas - just going by what i was told when i asked the question to 3 of the traders on this site! :)
Did they want to sell you some iridiums by any chance? :D
ha ha - yeah something like that.
to be straight with you i dont really know too much about it all as fairly new - so was just going on what i was told by some of the respected traders....who said that the copper ones are seriously not up to scratch on bpu and above........
...however if i'm wrong then fair enough - it wouldn't be the 1st time ;)
IMO when running BPU i would always go for some Copper plugs. After the det i heard at the turbo change over point on a standard ecu at 1bar i would not want to use some irridiums just incase the tips broke from the extreme pressure and heat.
Ryan
Ryan - any chance you could check with James @ ToyotaGT for me what he is ordering when he does the bpu for me? (not sure if he is getting them through you or not?)
i dont mind which ones he gets if they are ok, but its about £30 difference in price.... :)
