Strange clattering noise at full boost
Dash Rendar
The other day I was fortunate enough to be sat in the passenger seat of a T61 Supra. However, at full (sustained) boost there was a repetetive 'clacking' sound. Imagine hitting steel venetian blinds with a ruler at a rate of about 3 times per second... Only *much* louder. That's what it sounded like.
This wasn't apparent until full boost was achieved and sustained. I've been in big-singles before, and only ever heard the mighty 'whoosh' of air. I've never heard a turbo make a sound like this. It was almost as if pockets of air were slamming into something in the system at regular intervals.
The owner didn't know what could cause this. I was wondering if anyone has any ideas?
Did it sould a bit like a few small screws rattling around in a tin? - If so, that sounds worryingly like detonation - Too weak AFR possibly?
If was a fairly quiet repetative clicking coming from an auto gearbox, that has something to do with solenoids, but I can't elaborate any more than that.
It did have an AFR, but I didn't really get any chance to pay attention.
So what does a loud wastegate sound like? I thought that would be more like a BOV kind of noise... Only louder.
The owner of the car didn't seem too concerned with the noise, but I was just curious.
Cheers all.
I'm not sure what you mean Mike, the wastegate itself shouldn't make any noise, it's just a big valve thats either open or closed (or at some stage in between the two :D ). Are you referring to the noise from the exit?
The exhaust gases passing through a wastegate are often directed to atmosphere rather than routed back to the exhaust. The pipe is commonly called a screamer pipe - and for a good reason!
When the car reaches target boost all excess exhaust gases are directed out of the wastegate, down a short tube and out under the engine bay. These make an enormous amount of noise when the car is on full boost, it's basically an unsilenced exhaust pipe only 2 foot (or so) from the cylinder hence the name. However, it's just a constant 'scream' sound, there should be no oscillation of other noise coming from it.
There's something else going on there to cause the noise...
I have heard it in a number of singles. Granted when the screamer pipe is open then the noise is so loud that if you can hear anything else you are doing well! When I plummed my screamer back into the exhaust to shut it up you can hear the external wastegate operate. I'd best describe it as a chattering.. lots of small irregular pressure releases that sounds quite unusual. It's not very loud but it's noticable.
At least i hope it's that :blink:, no, just kidding; I'm 100% certain it is.. I have heard it in Michel's car too, and you can hear the same frequency of the noise, all be it at a greater volume in an open screamer pipe.
So Mike, if I'm understanding you right, the wastegate can open regularly at short intervals, to vent off excess boost in pockets? I guess if that sound was essentially being 'amplified' through the screamer pipe, it might explain it. Dunno...
Matt, why would you only hear this wastegate noise on lift-off? I thought the wastegate was venting the excess pressure, and that this would happen under full boost? Or is it because the wastegate should only close on lift-off, and that's the only sound you should hear? (This demonstrates my lack of knowledge regarding how a wastegate operates!)
