Connecting to a printer through a network
heartworm
Can anyone help with connecting to a printer on a network,
Hewplett packard 8550 colorlaser printer,
run the windows install thing/gone managed to get the drivers from the printer itself,
can ping the IP of the printer but i get an error that it cannot connect everytime I try print from it :@ so frustrating
==>Start ==>Printers and Faxes ==>Add Printer
==>Local Printer
but UNcheck the box: detect Plug and Play printer
Use existing port: LPT1
==>Create new port
==>Port type:
==>Standard TCP/IP port
(or ==>LPR port for Apple Laserwriter)
Port name or IP number: 10.63.40.81
port name: IP_10.63.40.81 (system will fill this in for you)
(Note: for LPR port:
port name: raw ("raw" is required)
==>Local Printer
==>Create new port
==>Port type:
Thats the way its been done, the printer IP is 10.0.0.20 and thats what we put in, but its still not connecting :S
are you 100% sure that no other device has that address?
yeah its running from that IP address on a MAC, and when you type that IP in it takes you to the machines software/driver installation and set up, which then gives the same message that it cant find the printer
switched my firewall off and its still doing the same thing.
Printer is answering when we ping it yeah.
What about internal printer settings? especially port etc? I remember I DID install this exact type of printer in LAN without any tricks at all. What's printer name at printer and Window side?
We cant really understand why its not working, it should be working cause everything that was done on other machines ha sbeen done,
What you mean by printer name, the IP?
I've never had a problem either. If you print out a printer configuration page does the TCP/IP section say anything different to what you expect?
No, everything seems to be as it should,
Im thinking itsmore likely to be a problem with my network settings since I cant get a few other network things to work, I cant get Itunes to work over the network too, it should play on the surround sound in the room over the network, and I cant get any torrents to work on the net either, ill have a look at the router settings
Edit: Just seen your answer - it is most likely then that port printer is working on is blocked on router.
