Need to re-install Windows - do I need a disk??
Conrad
We've just had a new Dell PC at home as our current one is so full of spy ware, viruses and junk it was getting unbearble to use.
The old one is still decent enough for web browsing so my brother can have it. Ideally I just want to format it and re-install windows. Thing is I don't have a restore disk or a Windows disk. Is it possible to get Windows XP or Vista off the net? (torrents etc).
Or maybe can I use a restore disk I have with the new Dell PC?
Either way I don't want to pay for something again that I've essentially already paid for....
If your old machine is a brand name it should have a system restore function if you go to all programmes --> accesories --> system restore.
On all of our semi modern computers it has a system restore which returns it to factory settings
As above
Or if not then you should have had a disk with a new purchase of any pc.
Get bootable version if possible and check what serial number you have on your old Dell computer (XP Home/Pro etc.) Start computer from bootable CD, take off partitions, create them again, format and then install. At least you will be sure you got rid of all trash from HDD :)
Edit:
Just to add - most of Dell computers have only 1 partiton. It's good to have at least 2 of them - around 20 GB for system partiton - keep only windows and stuff like Office, Nero etc. On second partiton save all your pictures, text documents, install games, keep movies etc etc. At least next time you will get some annoying crap or accidentially delete some system files, reinstalation will not wipe out all things you never realized you have/need and gone by then :p
