what to do with the stock TT
amigo5
Good day to u all,
I think i have a problem with my 2jz espically with the stock turbos. firstly i want to know at the normal drive at which rpm the turbos open or start boost. i daily drive my car at a highway at rbm 3 and 3.5 and it get heat and overheat because the turbos open at 1.8 or 2 rpm. isn't that at normal drive turbos open at 1.8 or 2 rpm or these is only on my case. i want the help my friends. WHAT should i do?:search:
and if i install a boost controller will it will work to help
note: my 2jz is a stock JDM model and stock boost is 10.8 psi.:rolleyes:
thanks for replying
i usually drive my car at the highway with 150 km or 95 mi for at least 1 hour and of course the turbo is spooling and this will be affect the heat and may blown my turbo
but isn't there a way to delay the turbos from start spooling at 1.8 rpm
the problem of heating is ok now i install 68c thermostat (since the stock thermostat is 82c) and aftermatket radiator
but i'm still thinking and searching for a way for the TT
by the way can anyone show me breifly how to install the boost contraoller (manual of auto bc)
