Steve Posted October 24, 2007 Share Posted October 24, 2007 5K 'ish? Could the car just be dropped off with you or would you just want the block? Link to comment Share on other sites More sharing options...
grahamc Posted October 24, 2007 Share Posted October 24, 2007 is this what the dyno graph looks like? minus the slightly lower numbers Link to comment Share on other sites More sharing options...
Wez Posted October 24, 2007 Author Share Posted October 24, 2007 Thats power vs AFR. Your power curve levels off at 5500 and then starts to drop at 6500. Mine is a little different. Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 24, 2007 Share Posted October 24, 2007 Could the car just be dropped off with you or would you just want the block? Just the short motor. But I could do the lot, remove and refit, although I tend to shy away from this. Link to comment Share on other sites More sharing options...
grahamc Posted October 24, 2007 Share Posted October 24, 2007 Thats power vs AFR. Your power curve levels off at 5500 and then starts to drop at 6500. Mine is a little different. http://www.zen85016.zen.co.uk/gallery/supradyno/wesdyno6.jpg Thats the hybrids running out of steam... But see the difference. BTW mine also has 264/264 cams Link to comment Share on other sites More sharing options...
Inferno Posted October 24, 2007 Share Posted October 24, 2007 Thats power vs AFR. Your power curve levels off at 5500 and then starts to drop at 6500. Mine is a little different. http://www.zen85016.zen.co.uk/gallery/supradyno/wesdyno6.jpg That is a very impressive power curve... almost makes you wonder why people bother with hybrids when you can put down power like that. Link to comment Share on other sites More sharing options...
Mike B Posted October 25, 2007 Share Posted October 25, 2007 Thats power vs AFR. Your power curve levels off at 5500 and then starts to drop at 6500. Mine is a little different. http://www.zen85016.zen.co.uk/gallery/supradyno/wesdyno6.jpg is it just me, or have you lost a chunk of low down power there and early spool? you car was famous for the spool.... very smooth graph though. Link to comment Share on other sites More sharing options...
Ryan.G Posted October 25, 2007 Share Posted October 25, 2007 The lower torque and later spool on the new dyno graph i exspect was down to the way the boost was being controlled. When i got it to 552bhp it was using a MBC and then the new 554bhp it was using an aem solenoid. I exspect it needs more duty lower down TBH but Wes got his original mapper to set this up as he is better with the software than me and actually likes AEM's MBC @ 1.3bar then dropping to 1.1bar hence torque drop off Aem Solenoid - Not sure on boost levels Without cams - Holding 1.4bar Can anyone over lay the 3 and maybe put on Homer t67 and ianc t67 Link to comment Share on other sites More sharing options...
Wez Posted October 25, 2007 Author Share Posted October 25, 2007 I need to fine tune my AEM solenoid Link to comment Share on other sites More sharing options...
Wez Posted October 25, 2007 Author Share Posted October 25, 2007 Can anyone over lay the 3 I can ask Charlie to overlay them if you like. Link to comment Share on other sites More sharing options...
Ryan.G Posted October 25, 2007 Share Posted October 25, 2007 I will ask charlie tonight to do it if I remember or you can if you come up Ryan Link to comment Share on other sites More sharing options...
Wez Posted October 25, 2007 Author Share Posted October 25, 2007 I have just emailed him, depending what time I finish sorting some other bits I might pop over Link to comment Share on other sites More sharing options...
dangerous brain Posted October 25, 2007 Share Posted October 25, 2007 According to this http://www.showoffyourcar.com//cars/TOYOTA/20925.jpg I've got a 272 exhaust cam and it doesn't say anything about an inlet cam so I will assume its stock. I don't know what all the other gumph says but I know the tubby was a T67 sized HKS T04R with a worn bearing. Heres the graph from Thor (yeah yeah yeah I know inflated power figures blah blah) http://spicyweasel.com/bryan/image-cache/Bryan%27s%20Car/thor%20dyno_disp800.jpg And the following day at Marlin motorsport http://spicyweasel.com/bryan/image-cache/Bryan%27s%20Car/dan%20dyno_disp800.jpg Dunno if thats of any help to the diagnosis here. Link to comment Share on other sites More sharing options...
