GeordieSteve Posted December 10, 2004 Share Posted December 10, 2004 grrrr I hate NT4. after an 80 hour week I'm stull in shit with a Nt4 server. I have a 2003 PDC and and NT4 server just running as a workstation (it's needed to host SQL 7). None of the users seem to be able to browse to the NT4 box. It keeps asking for a password. The 2003 PDC is running AD with DNS and DHCP and it looks like they're all pinging the correct IP addresses now. If you logged on to the PDC as an administrator you can browse to it fine but not when you logged on to a client machine (98 or XP) as a use. Any ideas? Link to comment Share on other sites More sharing options...
JustGav Posted December 10, 2004 Share Posted December 10, 2004 How did you set up the 2003 PDC?? Did you set it up in comp. mode or native mode, bear in mind NT4 can't handle native mode. Gav Link to comment Share on other sites More sharing options...
GeordieSteve Posted December 10, 2004 Author Share Posted December 10, 2004 The NT4 server wasn't in place at the time of the 2003 coming in. Brand new server built from scratch mate Link to comment Share on other sites More sharing options...
GeordieSteve Posted December 10, 2004 Author Share Posted December 10, 2004 Can't get the netlogon server to run on the NT4 box Removed it from server managed and tried again but no luck there. The NT4 box used to the the old PDC if that helps Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted December 10, 2004 Share Posted December 10, 2004 Ive had problems at work with my services, starting automatically that is. So ive stopped them and manually restarted them and they've worked I feel a big day of work coming soon you saying on client machien as administrator you cant browse box either? Link to comment Share on other sites More sharing options...
GeordieSteve Posted December 10, 2004 Author Share Posted December 10, 2004 When I log onto a client machine as an administrator it'll browse fine. Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted December 10, 2004 Share Posted December 10, 2004 well this is a permission problem then, if administrator does it fine from a client box. And unfortunatly for you im not at work! so cant tell you what groups my normal users use and that allows them to browse the box. Check the Domain Users on the Server and see what groups they are in **if your using a domain of course, didnt ask or is it a workgroup ** Link to comment Share on other sites More sharing options...
GeordieSteve Posted December 10, 2004 Author Share Posted December 10, 2004 I'm in the administrator group in user manager for domains and I can't browse to it Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted December 10, 2004 Share Posted December 10, 2004 ok well im off out now but last bit of advice before i go, is create a new group with permission for everything put yourself in it. try logging on and see if you can get on the box, then start removing some of the rights you have given to the group, then check you can log back on, and hopefully you can see what may be stopping you logging on etc... I would say a more technical route, but im not infront of server to tell you which settings to check! good luck mate ill check thread later see how u get on Link to comment Share on other sites More sharing options...
