ManwithSupra Posted October 14, 2007 Share Posted October 14, 2007 I need a bit of help regarding two area's i am bpu @1.2 bar and i want to keep an eye on these things as i have heard horror stories etc. AFR I want to measure AFR but not sure what i need to get etc, will i need to buy a wideband o2 sensor for AFR will it work with the stock ecu? - basicly what equipment do i need for this. EGT Again similar to the above what do i need to get? also what is the nominal value for EGT? also where would i position the sensor and is it a case of drilling into manifolds etc?? Sorry i am not 100% clued up on these two. Quote Link to comment Share on other sites More sharing options...
gaz1 Posted October 14, 2007 Share Posted October 14, 2007 a wideband is a good thing to have on bpu, egt gauge a little over the top i would think, as the twins don,t generate the heat of a single;) Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted October 14, 2007 Author Share Posted October 14, 2007 a wideband is a good thing to have on bpu, egt gauge a little over the top i would think, as the twins don,t generate the heat of a single;) Ok cool, thanks for that, So what will i need to monitor AFR? and will the stock ecu be able to still work with a wideband? Quote Link to comment Share on other sites More sharing options...
Steve Posted October 14, 2007 Share Posted October 14, 2007 Ok cool, thanks for that, So what will i need to monitor AFR? and will the stock ecu be able to still work with a wideband? You will need something like one of these to do this. You will also need to get a bung welded onto your decat pipe for this to screw into (unless its already there with a bolt blocking it). This will not be wired into the stock ECU so you will need to keep the stock narrowband sensor. This will just be a standalone device. Quote Link to comment Share on other sites More sharing options...
Guest mugg Posted October 14, 2007 Share Posted October 14, 2007 Inovative Lc1 X16 set up or the LM1 , that is the wideband and gauge all in one kit . You run your wideband as a stand alone not to replace your stock 02 sensor ......it can replace your stock one with recalibration .... but why bother unless your stock is stuffed .With that you have a chance to mis calibrate and that can lead to disaster . Just place the correct 02 bung to suit the LC1/LM1 sensor appoximatley 6'' 150 past your stock 02 , which would place it in the start or your midpipe ..hook it up as instructed , mount your gauge were you want and bingo ....AFR'S Monitored. http://www.innovatemotorsports.com/products/MTS.php http://www.innovatemotorsports.com/products/lm1.php You will probably see its running rich all over , with a small lean section on the pick up of the #2 turbo around the 4k rpm range . The EGT is really not required . Quote Link to comment Share on other sites More sharing options...
