neil tt Posted October 12, 2007 Share Posted October 12, 2007 Was wondering if anyone is running one of these on a Supra, I looking to go single on the Soarer, but a bit concerned about the lag. If its bad on the Supra, its going to be a waiste of time on the Soarer:( Link to comment Share on other sites More sharing options...
Guest coldflame Posted October 12, 2007 Share Posted October 12, 2007 i have one and its fine there is a bit of lag but not to much Link to comment Share on other sites More sharing options...
neil tt Posted October 12, 2007 Author Share Posted October 12, 2007 What RPM does it start to spool, because I have a 2500 it will be a little latter:) Link to comment Share on other sites More sharing options...
Guest coldflame Posted October 12, 2007 Share Posted October 12, 2007 it starts at 3000 and dosnt stop till you let off the pedal its fun Link to comment Share on other sites More sharing options...
neil tt Posted October 12, 2007 Author Share Posted October 12, 2007 I like the sound of that:d Link to comment Share on other sites More sharing options...
neil tt Posted October 12, 2007 Author Share Posted October 12, 2007 Can I ask how much you paid for the turbo and manifold:) Link to comment Share on other sites More sharing options...
Guest coldflame Posted October 12, 2007 Share Posted October 12, 2007 it is i bought the kit got it £4300 and the HKS waistgate sound wen releaseing is amazeing Link to comment Share on other sites More sharing options...
matt k Posted October 12, 2007 Share Posted October 12, 2007 Mine doesn't make serious boost until about 4k at 3k it only makes about 0.4 bar. Link to comment Share on other sites More sharing options...
n boost Posted October 13, 2007 Share Posted October 13, 2007 Mine makes full boost at around 4k. I love it when it kicks in and it doe's not seem very laggy as i have a 0.96 housing. Brilliant for the drag strip or motorway driving. Link to comment Share on other sites More sharing options...
Jake Posted October 13, 2007 Share Posted October 13, 2007 Brilliant for the drag strip or motorway driving. Cool! What times and trap speeds are you getting at the drag strip? Link to comment Share on other sites More sharing options...
neil tt Posted October 13, 2007 Author Share Posted October 13, 2007 The one I'm looking at is .82. If its not making full boost until 4000rpm on the Supra, on the Soarer I would be looking at closer to five, or would the .82 make a difference, it has come off a Soarer:) Link to comment Share on other sites More sharing options...
birdy Posted October 13, 2007 Share Posted October 13, 2007 have you looked at http://www.TO4R.com Link to comment Share on other sites More sharing options...
matt k Posted October 13, 2007 Share Posted October 13, 2007 If you want a quick spooling turbo, then i would advise a gt35r i have been in an auto with .68 a/r and a 6 speed with .82 a/r, both spool much quicker than the T04R. I am currenlty trying to decide whether to buy a gt35r or t61 or put a 3800 hi stall on my box. Link to comment Share on other sites More sharing options...
tooquicktostop Posted October 13, 2007 Share Posted October 13, 2007 Here is my T04R on the dyno, made 580 BHP at the fly Click here to watch T04R-Dyno-Run Link to comment Share on other sites More sharing options...
Andy-No-Knee Posted October 13, 2007 Share Posted October 13, 2007 Neil, I'm running a HKS 3037s on my Soarer, there is not much more lag than on the normal twins but alot more power. (375rwhp) and that has been detuned to that and the dyno run was in second gear not top. Link to comment Share on other sites More sharing options...
dangerous brain Posted October 13, 2007 Share Posted October 13, 2007 I swapped a HKS T04 R with a 0.96 a/r exhaust housing for a BL dbb T67. The turbo itself is obviously the same size as I used both the inlet and exhaust housing from the HKS one for the BL one. It may be just my imagination and it may be because the bearing was on its way out but the new turbo seems to spool quite a bit quicker than the old one did. For what its worth if you can get the HKS unit as a a DBB then do that especially if you have lag concerns. PS this is with an aristo thats obviously alot closer auto box behaviour to your soarer than a mk4 supe is. Link to comment Share on other sites More sharing options...
neil tt Posted October 13, 2007 Author Share Posted October 13, 2007 Thanks for all the replies, I am waiting to get some flow charts for my hybrids, and then will deciede if I need to go single, or can get more out of what I have. The car comes off the road at the end of the month, so time to strip down and change a few things Link to comment Share on other sites More sharing options...
dangerous brain Posted October 13, 2007 Share Posted October 13, 2007 You already done the cams and water injection, decent injectors with a good map? Link to comment Share on other sites More sharing options...
neil tt Posted October 13, 2007 Author Share Posted October 13, 2007 Here is my T04R on the dyno, made 580 BHP at the fly Click here to watch T04R-Dyno-Run Sounded amazing:d Link to comment Share on other sites More sharing options...
dangerous brain Posted October 13, 2007 Share Posted October 13, 2007 Mine drew a crowd when it was on thors dyno at JAE I can heartily recommend a screamer pipe as well Link to comment Share on other sites More sharing options...
