Anyone know anything about VR6 engines?
Faith Adopter
isv means Idle Stabilizer Valve, so if this goes wrong then your car will lose performance, have bad idling and use more fuel. if i think what you are on about then this is a common fault on them, the rubber pipe which connects to it splits. has your pipe split or am i talking bo%%ox?
Guest slow dog
noy only that you have a sensor on the water pipe there should be 3 together the blue does the fuel mix for the choke and screws up alot and is making your engine run rich change it you will feel a big power gain if it furked
