Will not select gear
Gamer
Where is the nipple Chris? I've not noticed one before and don't have a car handy :)
Taken from one of Chris's older posts
You will find the bleed nipple on the clutch slave cylinder, which is on the nearside of the bellhousing. Just bleed fresh fluid through until it comes out clean. Be aware fresh fluid is more "searching" than old tired stuff, so if the master or slave cylinder seals are tired the new fluid could create a leak, either fluid exiting, or air entering the system. Cheap brake fluid is fine, there's little or no heat put into the clutch fluid.
