IT Question. Adding Printers/logon script
scooby_doo_do
At the moment we have our printers on a print gateway and we add then to the user's machines manually. I was just wondering if there is a way somehow to automatically have them so that they are added when the user log's on, to the correct printer? I thought about writing a net use script and adding it to the logon.bat, but i'm sure there must be an easier way within active directory - so i can just add a printer to a user?
Any advice greatly appreiciated..
Thanks
Craig.
right obviously the .bat and .vbs both have to be in the scripts folder.
My login.bat looks like this:
@ECHO OFF
cls
printer.VBS
NET TIME \\BEDC02 /SET /YES
BEDC02 is my server name. You can add more into it like mapped drives and stuff. and that bit of script assumes you name the .vbs "printer.vbs"
Then the vbs file that just adds a printer to the pc looks like this:
' VBScript - to map a network printer
' Version 1.2 - 10th May 2005
Option Explicit
Dim objNetwork, strUNCPrinter
strUNCPrinter = "\\BEDC02\Pi520(153)"
Set objNetwork = CreateObject("WScript.Network")
objNetwork.AddWindowsPrinterConnection strUNCPrinter
WScript.Quit
' End of script.
and if you want that printer to be default I use this:
' VBScript - to map a network printer and set as default
' Version 1.3 - 30th Sept 2005
Option Explicit
strUNCPrinter = "\\BEDC02\PI520(153)"
' Here is where we set the default printer to strUNCPrinter
objNetwork.SetDefaultPrinter strUNCPrinter
WScript.Echo "Your Default Printer is now: " & strUNCPrinter
WScript.Quit
' End of script.
You would just need to change the "\\BEDC02\PI520(153)" part to point at the server share name of your printer.
KiXtart's good for this, adding printers (UNC paths) based on group membership.
I quite like the idea of publishing all the printers via IIS, and letting users pick which they prefer (assuming you complete all the 'location' boxes correctly) - KB323428 covers this quite nicely.
as long as your domain is 2003 operational level you can do it all with policies. even if you are only on 2000 level you can publish them to active directory and users can just search for them and add them. As long as they have a roaming profile or stay on the same machine they will only need to do it once.
