USB to Serial adaptor?
ADL Mark
Can anyone recommend a good USB to Serial adaptor that will work ok under Vista and not get grumpy connecting to things like ECU's and Dataloggers etc.?
There's plenty about but I'm not sure about the cheapy ~£25 ones in case they're a bit flakey. I have enough flakiness with Vista :rolleyes:
To be honest most of them are based off just a coupe of chipsets, so it's all much of a muchness.
You start getting problems when the device you're connecting to uses very precise timing, my PIC programmer is like this - as the USB to serial convertors are generallty not "real" RS-232 ports.
If you're on a laptop a good option would be a PCMCIA serial port...
