Starting problems, if YOu solve my probLEM YOu ArE A god.
Guest FKADizzmystar
Guest FKADizzmystar
if any1 can tell me the problem you are god. ok when i turn my key ON i hear all these clicking noises under the hood and then i try and start it, it allmost clicks over then it doesnt. ive check the battery, the fuel pump relay, fuses, starter relays and all that good stuff. ive ruled out the starter motor because the car wants to start. so im thinking its the fuel filter/fuel pressure problem somewhere. it was the first time i put one of those type of filters on (being the stock standard one) a car and maybe ive done it wrong and im starving the engine of fuel or its not getting enough pressure somewhere. well any help would be great, im not touching anymore till i get some ideas. ive read most of the post from other guys on this web site that have had similar probs, that why ive tryed half the stuff above.
cheers
Its your starter mate. The contacts are corroded/damaged. Either that or you need a new battery but your old one is holding enough charge to make it seem like its ok (shows full voltage but can deliver no current).
Get the starter out & examine the contacts. There's a how to for replacing the starter contacts & a rebuyild kit available IIRC.
Seems like there's a lot of this about http://www.mkivsupra.net/vbb/showthread.php?t=125788
I had almost exactly the same problem, battery seemed to be ok, car would unlock all lights would come on and everything but when you tried to start all that happened was a loud "click" sound (solenoid on starter motor activating) but nothing else would happen. Changed the battery and hey presto problem solved :)
been down this route with mine, speak to Jezz, clicky solanoid syndrom! bet the car has done 50-60k its common issue with the starter motor. About £40 for a new one and a few hours to fit simply because the two bolts are a PITA to get at!
Its the solanoid on the starter motor sounds exactly the same issue as I had, changed the battery same, changed the crank position sensor with a temp one to test it - same issue. Changed the starter motor - problem fixed.
Is it really sporadic when it happens or is it every time?
Guest FKADizzmystar
the battery looks new water levels are fine and i left it to charge over night and then trying it at "full" charge in the morning so im guessing the battery is ok. and with the starter motor it can acually sound like its almost starting the car but be brocken at the same time?
Guest FKADizzmystar
just unplugged the battery of my other supra and tryed it and it did the same thing. supose im going to have to bit the bullet and start playing around with the starter motor.
you can buy refurb kits can you not Chris? I have my old starter motor sat in the garage! May get it reconditioned and flog it!
I keep the repair parts in stock at all times, I do loads these days, I reckon people should consider having the starter refreshed at a major service, if it's done over 80,000 miles, say.
how much do you charge for the refurbs, or even just the parts if its easy enough? mmm mine only lasted 55k
