rxv8 Posted October 7, 2007 Share Posted October 7, 2007 hi all anyone know the bulb type to fit a uk tt,as i want to order some hids headlights thanks Link to comment Share on other sites More sharing options...
gaz1 Posted October 7, 2007 Share Posted October 7, 2007 9006 matey;) Link to comment Share on other sites More sharing options...
rxv8 Posted October 7, 2007 Author Share Posted October 7, 2007 cheers gaz...so do i just qoute 9006 bulb??? or is it h3 h4 aswell??? Link to comment Share on other sites More sharing options...
Nic Posted October 7, 2007 Share Posted October 7, 2007 9006/hb4 Link to comment Share on other sites More sharing options...
louisjames Posted October 7, 2007 Share Posted October 7, 2007 cheers gaz...so do i just qoute 9006 bulb??? or is it h3 h4 aswell??? 9006 are hard to get, i did my conversion last week, 9005 is all you need to quote plus your lum colour obv. the third pin at the top you snip 2mil off, and fits perfect. Link to comment Share on other sites More sharing options...
Nic Posted October 8, 2007 Share Posted October 8, 2007 9006 are hard to get, i did my conversion last week, 9005 is all you need to quote plus your lum colour obv. the third pin at the top you snip 2mil off, and fits perfect. 9006 should be easy to get, it is a very common bulb, I can supply if needed. Link to comment Share on other sites More sharing options...
robin Posted October 8, 2007 Share Posted October 8, 2007 I found loads of places that did 9006. http://www.xenonshop.co.uk/ http://www.librautomotive.co.uk http://www.convert2xenon.com/products.htm Link to comment Share on other sites More sharing options...
georigg Posted October 8, 2007 Share Posted October 8, 2007 Found this site on Ebay selling both UK spec and Jspec kits at £75 buy-it-now. http://cgi.ebay.co.uk/TOYOTA-SUPRA-HID-CONVERSION-KIT_W0QQitemZ290133466485QQihZ019QQcategoryZ10428QQrdZ1QQssPageNameZWD1VQQcmdZViewItem However on my BMW site, there has been some correspondence in the past concerning the acceptability of retro-fit kits as apparently some MOT garages will fail your car if it does not meet the Spec requirements of cars fitted with OE HID lighting. Apparently this spec requires a means of headlight cleaning and the ability of the lighting to be levelled, or self-levelling, because of the risk of the higher intensity light blinding oncoming vehicles. It apparently does not stop peeps fitting the kits though! For myself, I would rather instal xenon bulbs, the blue envelope type, rated at 6000K providing a very white light similar to an HID kit. (The lesser "K" rating bulbs are not so good). Hope above helpful. Rgds George Link to comment Share on other sites More sharing options...
robin Posted October 8, 2007 Share Posted October 8, 2007 Should be ok for UK cars as they have headlight washers and adjustable beams from in the car. I think I will still put normal bulbs in for the MOT though. Link to comment Share on other sites More sharing options...
RiceRocketUk Posted November 30, 2007 Share Posted November 30, 2007 what kit would you use if you had a j-spec but were fitting uk headlamps? any help would be appreciated Link to comment Share on other sites More sharing options...
Nic Posted December 1, 2007 Share Posted December 1, 2007 what kit would you use if you had a j-spec but were fitting uk headlamps? any help would be appreciated Low beam - HB4/9006 High beam - HB3/9005 Link to comment Share on other sites More sharing options...
RiceRocketUk Posted December 1, 2007 Share Posted December 1, 2007 thanks Nick, are the loom plugs for the bulbs not different on uk and j-spec£thought they were different widths), hence the fitting at the bulb end where it goes into the headlamp I know will be 9006 however will it be correct at the end where the light loom plug fits in Link to comment Share on other sites More sharing options...
Nic Posted December 1, 2007 Share Posted December 1, 2007 thanks Nick, are the loom plugs for the bulbs not different on uk and j-spec£thought they were different widths), hence the fitting at the bulb end where it goes into the headlamp I know will be 9006 however will it be correct at the end where the light loom plug fits in The plugs are the same on the J-spec and UK spec, they will fit perfectly. Link to comment Share on other sites More sharing options...
RiceRocketUk Posted December 1, 2007 Share Posted December 1, 2007 ok thanks Link to comment Share on other sites More sharing options...
