supradibbs Posted October 7, 2007 Share Posted October 7, 2007 What the hell is going car was running sweet as a nut when i took it into the bodyshop now its a sack off poo at 80 its off the scale lean then as i start to pull low rpm its really flat aslo showing very lean off throttle really hestite hard throttle fine?!?!?!?!?!? checked fuel pressure at idle showing 25psi gonna check the pumps tomorrow Anything else i could check??? Have my banzai photoshoot tomorrow so really need to sort this:( Link to comment Share on other sites More sharing options...
gaz1 Posted October 7, 2007 Share Posted October 7, 2007 thought the pressure idealy was 40 Link to comment Share on other sites More sharing options...
TT-DEK Posted October 7, 2007 Share Posted October 7, 2007 What where the figures Wayne?? Link to comment Share on other sites More sharing options...
supradibbs Posted October 7, 2007 Author Share Posted October 7, 2007 What where the figures Wayne?? what afrs off the scale rich at cruise normal on throttle idle 15-15.5 fuel pressure at idle 25 psi Link to comment Share on other sites More sharing options...
Ryan.G Posted October 7, 2007 Share Posted October 7, 2007 Check pump lines are not leaking as big blue cars who also had his worked on at TF was leaking in the tanks due to them using vacuum hose not fuel if i remember right. Then it just gave way. It put the map right out when it was fixed as the fuel pressure shot up but sound like you might have same problem where its just started leaking pressure. Hence running lean. Also make sure both pumps are running Good luck Ryan Link to comment Share on other sites More sharing options...
supradibbs Posted October 8, 2007 Author Share Posted October 8, 2007 gonnna start working on this now so a quick bumpsee if there are any other views Link to comment Share on other sites More sharing options...
