Guest Ponty Boy Posted December 6, 2004 Share Posted December 6, 2004 Hi. I've got a auto non turbo and have only had it a month or so but love it. I'm concerned at a noise that its making and hopefully sonme of you lot can help me. It only happens when i'm accelerating and is like a tapping/airy noise if that any help. Anybody know what to take alot at. Any help greatly received. Cheers, Rhys. Quote Link to comment Share on other sites More sharing options...
Digsy Posted December 7, 2004 Share Posted December 7, 2004 I get a "whistling" noise through the heater vents when I'm accelerating on my NA. Other people have reported it on here too. I don't think anyone has ever found the source. Quote Link to comment Share on other sites More sharing options...
AJI Posted December 7, 2004 Share Posted December 7, 2004 where is the noise coming from? the cockpit? the engine bay? the wheel area? etc. Quote Link to comment Share on other sites More sharing options...
Guest Ponty Boy Posted December 7, 2004 Share Posted December 7, 2004 Its coming from the engine bay, more of a putt putt putt type of noise. Speaking to a gut in work, he said it could be to do with the exhaust or one of the manifolds? Could it be this? Where do I look and tell? Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted December 7, 2004 Share Posted December 7, 2004 Could be an exhaust blow? Quote Link to comment Share on other sites More sharing options...
Guest Ponty Boy Posted December 7, 2004 Share Posted December 7, 2004 How can I check this or is it best popping to Kwik fit to run their eye over it? Quote Link to comment Share on other sites More sharing options...
The Hornet Posted December 7, 2004 Share Posted December 7, 2004 I've noticed a similar noise, think it's related to the aircon unit / heater system somehow. Grant Quote Link to comment Share on other sites More sharing options...
Nic Posted December 7, 2004 Share Posted December 7, 2004 To check if the exhaust is leaking, start car and then hold a wet rag against the end of the tail pipe to stop the exhaust gasses from coming out. You should hear the gasses escaping if it is leaking and the engine should continue to tick over, if the engine stalls then there is no leak. Quote Link to comment Share on other sites More sharing options...
Soop Dogg Posted December 7, 2004 Share Posted December 7, 2004 Originally posted by Nic To check if the exhaust is leaking, start car and then hold a wet rag against the end of the tail pipe to stop the exhaust gasses from coming out. You should hear the gasses escaping if it is leaking and the engine should continue to tick over, if the engine stalls then there is no leak. i can just picture him if he's got something like a Hyper on his car....that'll need a whole blanket to try and block up the exhaust!!! Quote Link to comment Share on other sites More sharing options...
Guest Ponty Boy Posted December 7, 2004 Share Posted December 7, 2004 Thanks i'll try that tonight. Probably going to use a towell as got a 5" exhaust! Quote Link to comment Share on other sites More sharing options...
Rob Posted December 7, 2004 Share Posted December 7, 2004 Originally posted by Soop Dogg i can just picture him if he's got something like a Hyper on his car....that'll need a whole blanket to try and block up the exhaust!!! I was thinking that as well, I suppose you could wrap a wet towel round your head and stick it in. A bit like Arnie in Total Recall. Quote Link to comment Share on other sites More sharing options...
