supraguye Posted October 5, 2007 Share Posted October 5, 2007 Got this list off supraforums.com.au, it's great for all those looking for Japanese spec part numbers, Can any of the moderators make this a sticky? FILTERS: air filter-#17801-07020 fuel filter-#23300-49195 oil filter-#90915-20004 [jap made] pcv valve-#12204-46020[TT] pcv valve-#12204-46030 [NA] pcv grommet-#90480-18001 FLUIDS: automatic-#08886-81015 type-t-iv getrag 6spd-#08885-01306 v160 antifreeze-#00272-1LLAC-01 Toyota Red engine oil- 5w30 or 10w30 differental oil- 75w-90 or equilivent disk brake grease-#08887-80609 WIPER PARTS: blade assy rh-#85212-33011 blade assy lh-#85222-14610 [also works on rh side] blade assy rear-#85242-14020 refill frt rh-#85214-YZZB7 refill frt lh-#85214-YZZB9 refill rear-#85214-YZZB6 arm rh-#85211-14310 arm lh-#85221-14310 arm rear-#85241-14020 TUNE UP PARTS: plugs-#90919-01178 [TT] ND platinum plugs-#90919-01210 [TT] ND iridium plugs-#90919-01168 [NA] ND platinum plugs ngk for bpu-#3330 dist cap-#19101-70020 [NA] dist rotor-#19102-46011 [NA] wires-#90919-21521 [NA] coil-#90919-02205 [TT] coil-#90919-02207 [NA 93.5-97] coil-#90919-02216 [NA 98] coil elec. plug repair-#90980-11246 BELTS: drive belt-#90916-02310[serpentine] drive belt tensioner-#16620-46070 [TT 6spd] drive belt tensioner-#16620-0W025 [NA all /TT auto] timing belt-#13568-49036 BRAKES: frt pads-#04465-14150 [TT for 4pot calipers] frt shims-#04945-14110[TT] frt clips-#04947-14010 [TT] frt pad pins-#90240-06019[TT] rear pads-#04466-14040 [TT] rear shims-#04946-14030 [TT] rear clips-#04948-14010 [TT] rear pad pins-#90240-06017 [TT] frt rotor rh-#43512-14200 [TT] frt rotor lh-#43516-14030 [TT] rear rotors-#42431-14150 [TT] cal kit frt-#04479-14140 [TT] cal kit rear-#04479-14130 [TT] cal assy frt rh-#47730-14260 [TT] cal assy frt lh-#47750-14270 [TT] cal assy rear rh-#47730-14270 [TT] cal assy rear lh-#47750-14280 [TT] frt pads-#04465-14081 [NA and 2pot caliper TT] frt shims-#04945-14010 [NA] frt clips-#04947-24030 [NA] frt cal pins-#47715-24010 [NA] rear pads-#04466-30030 [NA] rear shims-#04946-24010 [NA] rear clips-#04948-50010 [NA] rear cal pins main-#47715-06030 [NA] rear cal pins sub-#47715-06020 [NA] frt rotors-#43512-14190 [NA] rear rotors-#42431-30140 [NA 93.5-95] rear rotors-#42431-30240 [NA 96-98] cal kit frt-#04479-14120 [NA] cal kit rear-#04479-24030 [NA] cal assy frt rh-#47730-24082 [NA 93.5-94] cal assy frt lh-#47750-24082 [NA 93.5-94] cal assy frt rh-#47730-14281-84 [NA 95-98] cal assy frt lh-#47750-14291-84 [NA 95-98] cal assy rear rh-#47730-14240-84 [NA] cal assy rear lh-#47750-14240-84 [NA] WHEEL BEARINGS/SEALS frt axle hub-#43502-30140 frt wheel brg-#90903-63006-77 frt wheel seal-#90311-50008 rear axle hub-#42301-30030 rear wheel brg-#90369-43005-77 rear seal inner-#90311-63001 rear seal outer-#90311-57001 CLUTCH PARTS: pilot brg-#90363-12002-77 [TT-NA] t/o brg-#90903-63001 [TT] t/o brg-#31230-22100 [NA] clutch cover-#31210-14170-84 [TT] clutch cover-#31210-30261-84 [NA] clutch disc-#31250-14190 [TT] clutch disc-#31250-30391-84 [NA] clutch master-#31410-14310 clutch slave-#31470-22120 [NA] clutch slave-#31470-14060 [TT] clutch master kit-#04311-12110 clutch slave kit-#04313-14020 [TT] clutch slave kit-#04313-17010 [NA 93.5-96.5] clutch slave kit-#04313-22030 [NA 96.6-98] clutch fork-#31204-14060 [TT 6spd] clutch fork-#31204-22050 [NA 5spd] ENGINE PARTS: 02 sensor-#89465-19605 cam seals-#90311-40020 crank seal-#90311-46001 rear main seal-#90311-90006 v/c gskt intake-#11213-46020 v/c gskt exhaust-#11214-46011 v/c gskt exhaust-#11214-46030 [NA 98] silicone gasket sealer-#00295-00102 [the black stuff in a tube] pcv hose frt v/c-#12264-46010 [TT] pcv hose rear v/c-#12263-46010 [TT] fuel pump-#23221-46070 [NA 93.5-97] fuel pump-#23221-50060 [NA 98] fuel pump-#23221-46110 [TT] fuel pump brkt-#23206-46160 [TT] fuel pump brkt-#23206-46140 [NA] t-belt ilder-#13505-46041 t-belt tensioner-#13540-46030 t/stat-#90916-03093 t/stat gskt#16325-62010 w/pump-#16100-49837 [NA] w/pump-#16100-49846 [TT] rad cap-#16401-62100 alternator-#27060-46200-84 [TT 6spd] alternator-#27060-46120-84 [TT auto] alternator-#27060-46190-84 [NA 93.5-95.5] alternator-#27060-46050-84 [NA 95.6-98] starter-#28100-46140-84 engine mounts-#12360-46070[93.5-95.4] engine mounts-#12360-46111[95.5-98 improved design] trans mount-#12371-46110 [TT 6spd] trans mount-#12371-46120 [TT auto] trans mount-# 12371-46090[NA 5spd] trans mount-#12371-46020 [NA auto] radiator assy-#16400-46420 [TT 6spd Alumin.type] radiator assy-#16400-46430 [TT auto alumin.type] radiator assy-#16400-46290 [NA 5spd] radiator assy-#16400-46300 [NA auto] short block assy-#11400-49088 [TT] full gskt kit engine-#04111-46094 [TT] BODY PARTS: hatch stay rh-#68950-19895 [w/spoiler] hatch stay lh-#68960-19585 [w/spoiler] hatch rubber stopper-#67293-14051[stops the squeak] screws for above 2ea-#90159-50116 targa roof-#63201-14060 targa mld rh-#63217-14030-C0 targa mld lh-#63218-14020-C0 targa w/strip rh-#62383-14030 targa w/strip lh-#62384-14030 targa headliner-#63312-14050-C0 targa bolts frt-#90901-09004 targa bolt /brkt rear rh#63240-14090[2pc brkt w/bolt] targa bolt/ brkt rear lh#63240-14060 [2pc brkt w/bolt] targa ctr.lock assy-#63203-14100 HELICOIL KIT FOR TARGA BOLTS-#5546.6 [6mm x 1.0] turbo spoiler rear-#76085-14909 frt glass mld-#75533-14190 back glass mld-#75573-14210 floor carpet-#58510-1B171-A0 [ stick/ivory] floor carpet-#58510-1B171-C0 [stick/black] floor carpet-#58510-1B181-A0 [auto/ivory] floor carpet-#58510-1B181-C0 [auto/black] rear lisc.plate nuts-#52121-24020 tonneau cover trunk-#64910-14060-C0 power antenna-#86300-14411 power antenna mast only-#86337-14411[chrome only] ash tray-#74102-14130 [93.5-96] ash tray-#74102-14140 [97-98] ACCESSORIES: front end mask-#00218-14930 mudguards frt-#76095-14010 wheel locks-#00276-14930 floor mats blk/ivory logo-#00200-14930-08 floor mats blk/silver logo-#00200-14930-13 floor mats blk/SE logo-#00200-14950-01 [discontinued] EMBLEMS: gold NA kit -#00211-14950[no "turbo"logo]{discontinued} gold TT kit -#00211-14970 [w/"turbo" logo]{discontinued} gold SE kit-#00211-14954 {discontinued} gold SE logo only-#00211-14953 {discontinued} gold ctr cap logo-#00211-00951 gold ant. nut-#00577-35950 gold "logo"frt-#00211-14956 gold "toyota"-#00211-14951 gold "supra"-#00211-14952 gold "logo"rear-#00211-14957 15th anniv.logos-#00211-14971-01 blk 15th anniv.logos-#00211-14971-28 silver SE side stripes rh-#00211-4R951 SE side stripes lh-#00211-4L951 "turbo"logo -#00016-23940{small brushed Aluminium w/black letters used by Toyota Southeast Distributors.94-95?TT} frt cover "logo" grey-#75314-14010 tailgate "toyota"grey-#75441-14190 tailgate "logo" grey-#75471-14010 tailgate "supra" grey-#75442-14280[93.5-96 TT all NA] tailgate "supra turbo" grey-#75443-14180[97-98 TT] trd 3pack logo-#00602-42601-EMB[carbon fiber style 1"x2.75" "toyota racing development"red letters "TRD" chrome large letters] TRD SPORT PARTS: trd sway bar kit f&r-# 00602-48800-003 trd strut tower brace-#00602-53607-007 trd spring/strut kit-#00602-48000-008 [NA][discontinued] trd spring/strut kit-#00602-48000-009 [TT] [discontinued] trd SS brake lines-#00602-47300-012[discontinued] trd oil filter-#00642-90915-001 trd oil cap-#00602-12108-003 trd air filter-#00642-17801-002[oem style] trd rad cap-#00642-16401-003 trd clutch kit-#00602-31201-010 [TT] trd gen 2 exhaust cat back-#00602-17400-016 [TT] trd fuel pressure regulator-#00643-23280-000 trd brake pads-#00602,00643-XXXXX-XX [all discontinued] trd 10,000 rpm tach-#[all discontinued] DRIVETRAIN: getrag 6spd assy-#33030-0W212 silicone trans pan sealer-#00295-01281 [orange stuff] atm screen filter-#35330-30011 [NA 93.5-97] atm screen filter-#35330-50010 [TT /NA 98] drive shaft-#37100-14810 [TT 6spd] drive shaft-#37100-14820 [TT auto] rear diff pinion seal-#90311-50018 [6spd] rear diff pinion seal-#90311-44005[ TT auto-NA all] rear diff axle seals-#90311-45013 [6spd] rear diff axle seals-#90311-47008 [auto all/NA 5spd] input shaft seal-#90080-31037[TT 6spd] output shaft seal-#90080-31029[TT 6spd] shift rod case seal-#90080-31032[TT 6spd] OIL PRESSURE SENSOR MOD: union bolt-#90401-19008 gasket-#90430-20016 o ring-#90301-68005 EXTERIOR LIGHTING: 3rd stop lamp-#81570-14060[93.5-94] 3rd stop lamp-#81570-14061[95-98] head lamp lh-#81151-1B241 [98 style grey no bulbs] head lamp rh-#81111-1B241 [98 style grey no bulbs] tail lamp lh-#81561-14700 [98 style grey no bulbs] tail lamp rh-#81551-14700 [98 style grey no bulbs] t/s lamp frt rh-#81510-80086 [97-98 clear assy w/bulbs] t/s lamp frt lh-#81520-80086 [97-98 clear assy w/bulbs] t/s frt harness -#81515-14390[97-98 pig tail for aftermarket lamps] turn signal/hazzard flasher-#81980-12070 indicator-#81730-20220 [93.5-96 style indicators in clear]part is actually for the 2003 corolla but perfect fit for supra EXHAUST HARDWARE: lock nuts-#90179-08059 [8mm w/washer for 02 studs/ misc] lock nuts-#90179-10070 [10mm w/washer for studs / misc] bolts-#90105-10023 [ 10mm w/washer for exh pipes] nuts-#94180-41000 [10mm w/washer for exh pipes] studs-#90179-10070 [10mm for most mainfolds/exhaust] INSTRUMENT PANEL BEZELS 97/98 part# 55410-14530 ctr upper part# 55404-14570 lh dash part# 55420-14060 speedo bezel part# 55405-14170 radio/hvac panel part# 58804-14100 6spd shift bezel part# 58804-14110 atm shift bezel part#74232-14121 lh door switch bezel Link to comment Share on other sites More sharing options...
michael Posted October 5, 2007 Share Posted October 5, 2007 We have a list like this somewhere, I'd search for it but I'm tired. Thanks though Edit: http://www.mkivsupra.net/vbb/showthread.php?t=28013 http://www.mkivsupra.net/vbb/showpost.php?p=274258&postcount=5 Link to comment Share on other sites More sharing options...
supraguye Posted October 5, 2007 Author Share Posted October 5, 2007 oops ... Didn't realise michael Link to comment Share on other sites More sharing options...
Thorin Posted October 5, 2007 Share Posted October 5, 2007 This perhaps? The list isn't as neat though... http://www.mkivsupra.net/vbb/showthread.php?t=28013 Link to comment Share on other sites More sharing options...
michael Posted October 5, 2007 Share Posted October 5, 2007 oops ... Didn't realise michael No panic, there might be numbers on both lists that might not be on the other, can't do any harm to have them both. Link to comment Share on other sites More sharing options...
supraguye Posted October 5, 2007 Author Share Posted October 5, 2007 Would be great if the moderators could make it a sticky as i know alot of people are after it. Link to comment Share on other sites More sharing options...
little num Posted September 22, 2008 Share Posted September 22, 2008 this is helping me no end i be stuck without all these part numbers cheers supraguye for doing this. Link to comment Share on other sites More sharing options...
hoff Posted September 22, 2008 Share Posted September 22, 2008 Countless times Ive searched for this and hardly ever find it. I'll find it from now on though;) Couple of the links dont work but still helpfull:) Link to comment Share on other sites More sharing options...
