Part Numbers from http://www.supraforums.com.au/
supraguye
Got this list off supraforums.com.au, it's great for all those looking for Japanese spec part numbers, Can any of the moderators make this a sticky?
FILTERS:
air filter-#17801-07020
fuel filter-#23300-49195
oil filter-#90915-20004 [jap made]
pcv valve-#12204-46020[TT]
pcv valve-#12204-46030 [NA]
pcv grommet-#90480-18001
FLUIDS:
automatic-#08886-81015 type-t-iv
getrag 6spd-#08885-01306 v160
antifreeze-#00272-1LLAC-01 Toyota Red
engine oil- 5w30 or 10w30
differental oil- 75w-90 or equilivent
disk brake grease-#08887-80609
WIPER PARTS:
blade assy rh-#85212-33011
blade assy lh-#85222-14610 [also works on rh side]
blade assy rear-#85242-14020
refill frt rh-#85214-YZZB7
refill frt lh-#85214-YZZB9
refill rear-#85214-YZZB6
arm rh-#85211-14310
arm lh-#85221-14310
arm rear-#85241-14020
TUNE UP PARTS:
plugs-#90919-01178 [TT] ND platinum
plugs-#90919-01210 [TT] ND iridium
plugs-#90919-01168 [NA] ND platinum
plugs ngk for bpu-#3330
dist cap-#19101-70020 [NA]
dist rotor-#19102-46011 [NA]
wires-#90919-21521 [NA]
coil-#90919-02205 [TT]
coil-#90919-02207 [NA 93.5-97]
coil-#90919-02216 [NA 98]
coil elec. plug repair-#90980-11246
BELTS:
drive belt-#90916-02310[serpentine]
drive belt tensioner-#16620-46070 [TT 6spd]
drive belt tensioner-#16620-0W025 [NA all /TT auto]
timing belt-#13568-49036
BRAKES:
frt pads-#04465-14150 [TT for 4pot calipers]
frt shims-#04945-14110[TT]
frt clips-#04947-14010 [TT]
frt pad pins-#90240-06019[TT]
rear pads-#04466-14040 [TT]
rear shims-#04946-14030 [TT]
rear clips-#04948-14010 [TT]
rear pad pins-#90240-06017 [TT]
frt rotor rh-#43512-14200 [TT]
frt rotor lh-#43516-14030 [TT]
rear rotors-#42431-14150 [TT]
cal kit frt-#04479-14140 [TT]
cal kit rear-#04479-14130 [TT]
cal assy frt rh-#47730-14260 [TT]
cal assy frt lh-#47750-14270 [TT]
cal assy rear rh-#47730-14270 [TT]
cal assy rear lh-#47750-14280 [TT]
frt pads-#04465-14081 [NA and 2pot caliper TT]
frt shims-#04945-14010 [NA]
frt clips-#04947-24030 [NA]
frt cal pins-#47715-24010 [NA]
rear pads-#04466-30030 [NA]
rear shims-#04946-24010 [NA]
rear clips-#04948-50010 [NA]
rear cal pins main-#47715-06030 [NA]
rear cal pins sub-#47715-06020 [NA]
frt rotors-#43512-14190 [NA]
rear rotors-#42431-30140 [NA 93.5-95]
rear rotors-#42431-30240 [NA 96-98]
cal kit frt-#04479-14120 [NA]
cal kit rear-#04479-24030 [NA]
cal assy frt rh-#47730-24082 [NA 93.5-94]
cal assy frt lh-#47750-24082 [NA 93.5-94]
cal assy frt rh-#47730-14281-84 [NA 95-98]
cal assy frt lh-#47750-14291-84 [NA 95-98]
cal assy rear rh-#47730-14240-84 [NA]
cal assy rear lh-#47750-14240-84 [NA]
WHEEL BEARINGS/SEALS
frt axle hub-#43502-30140
frt wheel brg-#90903-63006-77
frt wheel seal-#90311-50008
rear axle hub-#42301-30030
rear wheel brg-#90369-43005-77
rear seal inner-#90311-63001
rear seal outer-#90311-57001
CLUTCH PARTS:
pilot brg-#90363-12002-77 [TT-NA]
t/o brg-#90903-63001 [TT]
t/o brg-#31230-22100 [NA]
clutch cover-#31210-14170-84 [TT]
clutch cover-#31210-30261-84 [NA]
clutch disc-#31250-14190 [TT]
clutch disc-#31250-30391-84 [NA]
clutch master-#31410-14310
clutch slave-#31470-22120 [NA]
clutch slave-#31470-14060 [TT]
clutch master kit-#04311-12110
clutch slave kit-#04313-14020 [TT]
clutch slave kit-#04313-17010 [NA 93.5-96.5]
clutch slave kit-#04313-22030 [NA 96.6-98]
clutch fork-#31204-14060 [TT 6spd]
clutch fork-#31204-22050 [NA 5spd]
ENGINE PARTS:
02 sensor-#89465-19605
cam seals-#90311-40020
crank seal-#90311-46001
rear main seal-#90311-90006
v/c gskt intake-#11213-46020
v/c gskt exhaust-#11214-46011
v/c gskt exhaust-#11214-46030 [NA 98]
silicone gasket sealer-#00295-00102 [the black stuff in a tube]
pcv hose frt v/c-#12264-46010 [TT]
pcv hose rear v/c-#12263-46010 [TT]
fuel pump-#23221-46070 [NA 93.5-97]
fuel pump-#23221-50060 [NA 98]
fuel pump-#23221-46110 [TT]
fuel pump brkt-#23206-46160 [TT]
fuel pump brkt-#23206-46140 [NA]
t-belt ilder-#13505-46041
t-belt tensioner-#13540-46030
t/stat-#90916-03093
t/stat gskt#16325-62010
w/pump-#16100-49837 [NA]
w/pump-#16100-49846 [TT]
rad cap-#16401-62100
alternator-#27060-46200-84 [TT 6spd]
alternator-#27060-46120-84 [TT auto]
alternator-#27060-46190-84 [NA 93.5-95.5]
alternator-#27060-46050-84 [NA 95.6-98]
starter-#28100-46140-84
engine mounts-#12360-46070[93.5-95.4]
engine mounts-#12360-46111[95.5-98 improved design]
trans mount-#12371-46110 [TT 6spd]
trans mount-#12371-46120 [TT auto]
trans mount-# 12371-46090[NA 5spd]
trans mount-#12371-46020 [NA auto]
radiator assy-#16400-46420 [TT 6spd Alumin.type]
radiator assy-#16400-46430 [TT auto alumin.type]
radiator assy-#16400-46290 [NA 5spd]
radiator assy-#16400-46300 [NA auto]
short block assy-#11400-49088 [TT]
full gskt kit engine-#04111-46094 [TT]
BODY PARTS:
hatch stay rh-#68950-19895 [w/spoiler]
hatch stay lh-#68960-19585 [w/spoiler]
hatch rubber stopper-#67293-14051[stops the squeak]
screws for above 2ea-#90159-50116
targa roof-#63201-14060
targa mld rh-#63217-14030-C0
targa mld lh-#63218-14020-C0
targa w/strip rh-#62383-14030
targa w/strip lh-#62384-14030
targa headliner-#63312-14050-C0
targa bolts frt-#90901-09004
targa bolt /brkt rear rh#63240-14090[2pc brkt w/bolt]
targa bolt/ brkt rear lh#63240-14060 [2pc brkt w/bolt]
targa ctr.lock assy-#63203-14100
HELICOIL KIT FOR TARGA BOLTS-#5546.6 [6mm x 1.0]
turbo spoiler rear-#76085-14909
frt glass mld-#75533-14190
back glass mld-#75573-14210
floor carpet-#58510-1B171-A0 [ stick/ivory]
floor carpet-#58510-1B171-C0 [stick/black]
floor carpet-#58510-1B181-A0 [auto/ivory]
floor carpet-#58510-1B181-C0 [auto/black]
rear lisc.plate nuts-#52121-24020
tonneau cover trunk-#64910-14060-C0
power antenna-#86300-14411
power antenna mast only-#86337-14411[chrome only]
ash tray-#74102-14130 [93.5-96]
ash tray-#74102-14140 [97-98]
ACCESSORIES:
front end mask-#00218-14930
mudguards frt-#76095-14010
wheel locks-#00276-14930
floor mats blk/ivory logo-#00200-14930-08
floor mats blk/silver logo-#00200-14930-13
floor mats blk/SE logo-#00200-14950-01 [discontinued]
EMBLEMS:
gold NA kit -#00211-14950[no "turbo"logo]{discontinued}
gold TT kit -#00211-14970 [w/"turbo" logo]{discontinued}
gold SE kit-#00211-14954 {discontinued}
gold SE logo only-#00211-14953 {discontinued}
gold ctr cap logo-#00211-00951
gold ant. nut-#00577-35950
gold "logo"frt-#00211-14956
gold "toyota"-#00211-14951
gold "supra"-#00211-14952
gold "logo"rear-#00211-14957
15th anniv.logos-#00211-14971-01 blk
15th anniv.logos-#00211-14971-28 silver
SE side stripes rh-#00211-4R951
SE side stripes lh-#00211-4L951
"turbo"logo -#00016-23940{small brushed Aluminium w/black letters used by Toyota Southeast Distributors.94-95?TT}
frt cover "logo" grey-#75314-14010
tailgate "toyota"grey-#75441-14190
tailgate "logo" grey-#75471-14010
tailgate "supra" grey-#75442-14280[93.5-96 TT all NA]
tailgate "supra turbo" grey-#75443-14180[97-98 TT]
trd 3pack logo-#00602-42601-EMB[carbon fiber style 1"x2.75" "toyota racing development"red letters "TRD" chrome large letters]
TRD SPORT PARTS:
trd sway bar kit f&r-# 00602-48800-003
trd strut tower brace-#00602-53607-007
trd spring/strut kit-#00602-48000-008 [NA][discontinued]
trd spring/strut kit-#00602-48000-009 [TT] [discontinued]
trd SS brake lines-#00602-47300-012[discontinued]
trd oil filter-#00642-90915-001
trd oil cap-#00602-12108-003
trd air filter-#00642-17801-002[oem style]
trd rad cap-#00642-16401-003
trd clutch kit-#00602-31201-010 [TT]
trd gen 2 exhaust cat back-#00602-17400-016 [TT]
trd fuel pressure regulator-#00643-23280-000
trd brake pads-#00602,00643-XXXXX-XX [all discontinued]
trd 10,000 rpm tach-#[all discontinued]
DRIVETRAIN:
getrag 6spd assy-#33030-0W212
silicone trans pan sealer-#00295-01281 [orange stuff]
atm screen filter-#35330-30011 [NA 93.5-97]
atm screen filter-#35330-50010 [TT /NA 98]
drive shaft-#37100-14810 [TT 6spd]
drive shaft-#37100-14820 [TT auto]
rear diff pinion seal-#90311-50018 [6spd]
rear diff pinion seal-#90311-44005[ TT auto-NA all]
rear diff axle seals-#90311-45013 [6spd]
rear diff axle seals-#90311-47008 [auto all/NA 5spd]
input shaft seal-#90080-31037[TT 6spd]
output shaft seal-#90080-31029[TT 6spd]
shift rod case seal-#90080-31032[TT 6spd]
OIL PRESSURE SENSOR MOD:
union bolt-#90401-19008
gasket-#90430-20016
o ring-#90301-68005
EXTERIOR LIGHTING:
3rd stop lamp-#81570-14060[93.5-94]
3rd stop lamp-#81570-14061[95-98]
head lamp lh-#81151-1B241 [98 style grey no bulbs]
head lamp rh-#81111-1B241 [98 style grey no bulbs]
tail lamp lh-#81561-14700 [98 style grey no bulbs]
tail lamp rh-#81551-14700 [98 style grey no bulbs]
t/s lamp frt rh-#81510-80086 [97-98 clear assy w/bulbs]
t/s lamp frt lh-#81520-80086 [97-98 clear assy w/bulbs]
t/s frt harness -#81515-14390[97-98 pig tail for aftermarket lamps]
turn signal/hazzard flasher-#81980-12070
indicator-#81730-20220 [93.5-96 style indicators in clear]part is actually for the 2003 corolla but perfect fit for supra
EXHAUST HARDWARE:
lock nuts-#90179-08059 [8mm w/washer for 02 studs/ misc]
lock nuts-#90179-10070 [10mm w/washer for studs / misc]
bolts-#90105-10023 [ 10mm w/washer for exh pipes]
nuts-#94180-41000 [10mm w/washer for exh pipes]
studs-#90179-10070 [10mm for most mainfolds/exhaust]
INSTRUMENT PANEL BEZELS 97/98
part# 55410-14530 ctr upper
part# 55404-14570 lh dash
part# 55420-14060 speedo bezel
part# 55405-14170 radio/hvac panel
part# 58804-14100 6spd shift bezel
part# 58804-14110 atm shift bezel
part#74232-14121 lh door switch bezel
  • 11 months later...
