Guest gareth - track Posted October 3, 2007 Share Posted October 3, 2007 Can anyone tell me if n/a injectors will fit a 2jz I just want to know if there fit or not? Been offered some big cc injectors but there from a n/a engine Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted October 3, 2007 Share Posted October 3, 2007 You'll have to be a bit more specific chap. Which N/A engine did they come from (I won't assume its a 2jz-ge) What size and type are the injectors? Did the car they came from have an aftermarket fuel rail? Many questions before you can be given a 100% sure answer my fellow. Quote Link to comment Share on other sites More sharing options...
Guest kponx Posted June 9, 2008 Share Posted June 9, 2008 I think supra 2JZ-GTE is the twin turbos...and 2JZ-GE is the NA..Just add the info to let u know guys...cheers.. Quote Link to comment Share on other sites More sharing options...
bolarbag Posted June 9, 2008 Share Posted June 9, 2008 Can anyone tell me if n/a injectors will fit a 2jz I just want to know if there fit or not? Been offered some big cc injectors but there from a n/a engine Are you intending to go single turbo e.t.c? There is no need to go higher than the US/UK spec 550's if your not, if you wish to keep the stock fuel rail then I'm sure there are 720's that drop straight in, but as mentioned are not needed for bpu You also have to take into account what type of injectors they are if you are intending a management system(ecu) to control them, i.e. low impedance/high impedance Lastly, if you do buy them I'd advise getting these injectors flow tested, you dont want to drop them in and find you've blown a nice hole in your piston because one has stopped working or has picked up debris in transit, better to be safe than sorry;) Flow testing is around 100-120quid on top Quote Link to comment Share on other sites More sharing options...
JustGav Posted June 9, 2008 Share Posted June 9, 2008 The NA is top feed whereas the TT injectors are side feed Quote Link to comment Share on other sites More sharing options...
Alex Posted June 9, 2008 Share Posted June 9, 2008 The NA is top feed whereas the TT injectors are side feed Which would = no to the original question. Am I right in thinking they are 330cc in the NA? Quote Link to comment Share on other sites More sharing options...
Nic Posted June 9, 2008 Share Posted June 9, 2008 I think supra 2JZ-GTE is the twin turbos...and 2JZ-GE is the NA..Just add the info to let u know guys...cheers.. Thanks that is very useful to know. Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 9, 2008 Share Posted June 9, 2008 Which would = no to the original question. Am I right in thinking they are 330cc in the NA? Yup, 330 top feed in NA. Quote Link to comment Share on other sites More sharing options...
Thorin Posted June 9, 2008 Share Posted June 9, 2008 Thanks that is very useful to know. Sarcasm meter going off the scale here. Quote Link to comment Share on other sites More sharing options...
movistar Posted June 9, 2008 Share Posted June 9, 2008 Thanks that is very useful to know. Quote Link to comment Share on other sites More sharing options...
Nic Posted June 9, 2008 Share Posted June 9, 2008 Sarcasm meter going off the scale here. I don't understand it was a thread resurrected from last year with some really useful information that we should all be aware of. Quote Link to comment Share on other sites More sharing options...
JustGav Posted June 9, 2008 Share Posted June 9, 2008 Which would = no to the original question. Am I right in thinking they are 330cc in the NA? Yeah, 330cc I believe as well (I had heard a rumour of 370cc, but never looked into it) Quote Link to comment Share on other sites More sharing options...
JustGav Posted June 9, 2008 Share Posted June 9, 2008 I don't understand it was a thread resurrected from last year with some really useful information that we should all be aware of. Hahaha, I didn't even notice the dates.... whoops. Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted June 9, 2008 Share Posted June 9, 2008 That statement does'nt really justify bringing this thread back from the dead does it?!?!:rlol: Quote Link to comment Share on other sites More sharing options...
