SupraD06 Posted October 1, 2007 Share Posted October 1, 2007 Hi guys, just a quick question, just recently ive noticed my steering wheel start shaking once i bring in the second turbo, it never used to do this and ive taken it to a few garages and asked them cuz i thought it might be either tracking, wheel balancing, etc, ive checked all the tyre pressures are correct what else could it be? Link to comment Share on other sites More sharing options...
TRD3000GT Posted October 1, 2007 Share Posted October 1, 2007 possible you could have bearing wear in one of both hubs. this may be why you only feel this when the second turbo comes on line and they are under stress. Is it steadily getting worse? Link to comment Share on other sites More sharing options...
hogmaw Posted October 1, 2007 Share Posted October 1, 2007 Did you get the tracking/balancing done, and you still have the same problem? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 1, 2007 Share Posted October 1, 2007 Could also be down to brake disc warping, quite common. Link to comment Share on other sites More sharing options...
TRD3000GT Posted October 2, 2007 Share Posted October 2, 2007 Could also be down to brake disc warping, quite common. wheel wobble is only apparent when braking if its due to warped discs Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 2, 2007 Share Posted October 2, 2007 wheel wobble is only apparent when braking if its due to warped discs LOL I should read the post properly:innocent: Link to comment Share on other sites More sharing options...
SupraD06 Posted October 2, 2007 Author Share Posted October 2, 2007 had the tracking done, yes, it doesnt seem to be getting worse at the moment but i went out in it again today and i didnt do it for a while then later it did it again, its not a major pull or tug its just got some play when you drive and you feel your hands vibrate quite alot. Link to comment Share on other sites More sharing options...
