Going away - anything i need to do?
rick001
Is there anything i would need to do i.e. disconnect battery, as im going away for 2 weeks? :search:
cheers
Nah , nothing need doing as you are only away for 2 weeks. I have left my cars for 3 or 4 weeks in the past and they are fine on my return . Obviously the hand brake can stick a bit but has always immediatley free off when the car is first moved slightly.
Thanks mark, peace of mind really :D
If I was leaving the car whilst going on holiday I would disable it in more than one way so it's still there when you get back. ;)
:yeahthat: i normally take a few bits out, one being the ignitor and a picture of myself as they may not be able to resist once they see me! Could put a pic of havard in as a deterant though :D:D
Yep just what I was thinking do everything you can to make sure its not driven anywhere!
Also I'd leave it in gear ( or park ) with the handbrake off or at least on only the first click or 2 if youre on a relatively flat piece of road, handbrakes stick on so easily.
