M4RK RZ Posted October 1, 2007 Share Posted October 1, 2007 Alright chaps - Sooooooo spent a few hours fitting my new HKS EVC VI boost controller at weekend and of course removed my old knackered apexi boost controller + harness etc.. Traced 4 wires back to ECU (need to check old instructions but im guessing x2 for throttle and revs + x2 for pos/neg) Found that my ECU has 3 stickers on it ? One sticker is the Toyota one - small square paper type sticker with some codes on -like the pic attached Then there were a further 2 stickers - holographic effect with a company name+the word "Software" under it. One was stuck on the main lid plate and the other from the side to the lid (warrenty VOID if opened style - also holographic) They are not the type of sticker you would expec Toyota to put on there put it that way. Does anyone have a pic of a normal ECU? I am also the first to own this car in the UK with one prev owner in Japan. L reg 94 Twin Turbo I need to check the name on the sticker again as im at work at min but im guessing that my ECU is not normal anymore Who can suggest a way to check what it has been set to ? Or I could be TOTALY wrong Link to comment Share on other sites More sharing options...
Ryan.G Posted October 1, 2007 Share Posted October 1, 2007 Is that a pic of your ecu? As says A/T on it which i would assume means Automatic Transmission and looking at your garage you have manual Link to comment Share on other sites More sharing options...
M4RK RZ Posted October 1, 2007 Author Share Posted October 1, 2007 Is that a pic of your ecu? As says A/T on it which i would assume means Automatic Transmission and looking at your garage you have manual Nooooooo mate thats just an ECU i found on the web to show the toyota style sticker . Mine has aditional stickers on it like its been modded some place? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 1, 2007 Share Posted October 1, 2007 Can't see anything but the factory sticker in the pic? Link to comment Share on other sites More sharing options...
Ryan.G Posted October 1, 2007 Share Posted October 1, 2007 Post a pic of the logo's mark Sound like it might have a modified board from mines, toms etc Link to comment Share on other sites More sharing options...
M4RK RZ Posted October 1, 2007 Author Share Posted October 1, 2007 Yer ill do that - sorry ive come half cocked with info into this one. Ill take a pic asap. Link to comment Share on other sites More sharing options...
steb9780 Posted October 1, 2007 Share Posted October 1, 2007 Yeah mine has a mine's certificate suck to it. Link to comment Share on other sites More sharing options...
M4RK RZ Posted October 1, 2007 Author Share Posted October 1, 2007 Yeah mine has a mine's certificate suck to it. ahhh cool - looks like there is going to be some thing going on in mine too then. Will get a pic assap do you know what has been done to yours? Link to comment Share on other sites More sharing options...
hadyn Posted October 1, 2007 Share Posted October 1, 2007 Sounds like a mines/blitz etc ecu. They basically take stock ecus and 'play' with them to raise fuel cut, rev limit, change fuel mapping etc. You can usually find a sticker on them by the toyota badges etc... Link to comment Share on other sites More sharing options...
Nick Posted October 2, 2007 Share Posted October 2, 2007 If it's a Mine's ECU send me a PM with the original ECU number and Mine's serial number. I'm a distributor and if they have it on file then I'll be able to tell you the basic map settings such as boost limit, injector size etc. Link to comment Share on other sites More sharing options...
steb9780 Posted October 2, 2007 Share Posted October 2, 2007 If it's a Mine's ECU send me a PM with the original ECU number and Mine's serial number. I'm a distributor and if they have it on file then I'll be able to tell you the basic map settings such as boost limit, injector size etc. That's handy Nick, so could they have put bigger injectors in my car too? My car was running about 1.3-1.4 bar when I got a decent gauge in it ( the GReddy in it when bought was faulty). I backed it off as I didn't know the car's setup. I set it to 1.2 bar to be a bit safer. I thought it might be bpu+ but couldn't be certain, so backed it off. Link to comment Share on other sites More sharing options...
steb9780 Posted October 2, 2007 Share Posted October 2, 2007 ahhh cool - looks like there is going to be some thing going on in mine too then. Will get a pic assap do you know what has been done to yours? No not really. I just know it was advertised with it and when I took the sat nav out I noticed the mine's sticker on the ecu casing. My friend @ RB motorsport said that generally on skylines they tweak the ecu to get the best out of the Japanese fuel. But that was on skylines. Link to comment Share on other sites More sharing options...
Nick Posted October 2, 2007 Share Posted October 2, 2007 Wise move backing off. I really wouldn't run 1.4bar, 1.2bar at the most. Also remember that Japanese fuel is 100RON.... For the Skylines they have several options depending on the injectors, turbos, cams etc. I'm not familiar with what they do with the Supra, but I expect it'll either be a basic boost up with the speed limiter removed, or one of their kits that uses 540cc injectors and a larger fuel pump. The best thing to do is give me the serial numbers so I can double check. Link to comment Share on other sites More sharing options...
M4RK RZ Posted October 2, 2007 Author Share Posted October 2, 2007 Cheers chaps - ill get back asap with pics - not well today tho Link to comment Share on other sites More sharing options...
M4RK RZ Posted October 2, 2007 Author Share Posted October 2, 2007 Sorted out some pics - here they are Sorry the sticker pic is blured - it was difficult to take a pic and get focus on the holographic surface + reflection etc.. On my ECU pic you cas see the 2nd sticker located on the main lid above the toyota one. The sticker says: ACUTE - Special Computers And all the plastic snap on connectors (already on there) I have replaced with a spliced solder joint Link to comment Share on other sites More sharing options...
hadyn Posted October 2, 2007 Share Posted October 2, 2007 Looks like someone has 'chipped' it then in japan. Never heard of acute, but something may have been done to your ecu Link to comment Share on other sites More sharing options...
M4RK RZ Posted October 2, 2007 Author Share Posted October 2, 2007 It looks that way but if anyone can give me more information about this I would be greatfull !!!! IM hoping fuel cut and things are done then - esp now I just fittted new boost controller can you diagnose the ECU via laptop to check it against original settings? Link to comment Share on other sites More sharing options...
jaymdee Posted October 3, 2007 Share Posted October 3, 2007 Mark, Probably wrong, but noticed your ECU sticker says 2JZ-GT. I would have thought it would say 2JZ-GTE as yours is a Turbo? Link to comment Share on other sites More sharing options...
M4RK RZ Posted October 3, 2007 Author Share Posted October 3, 2007 It does mate have look at the second ecu sets of pics Link to comment Share on other sites More sharing options...
Nick Posted October 4, 2007 Share Posted October 4, 2007 I've never heard of Acute either. Link to comment Share on other sites More sharing options...
jaymdee Posted October 4, 2007 Share Posted October 4, 2007 It does mate have look at the second ecu sets of pics I was meaning the second set of pics. The ECU is on the right and unless the E hasn't come out in the pic, only says 2JZ-GT. The Throttle Control says 2JZ-GTE. Just a bit confused that one says GTE and the other GT Link to comment Share on other sites More sharing options...
M4RK RZ Posted October 4, 2007 Author Share Posted October 4, 2007 Not a clue then - anyone know ? The car works fine? Link to comment Share on other sites More sharing options...
steb9780 Posted October 22, 2007 Share Posted October 22, 2007 An update on what the Mine's ones look like. I thought I'd better have a look, whilst I had the tools out today. Nick if you could find anything out about the plaque number 04386 I would be more than grateful. Pics of the plaque below: Link to comment Share on other sites More sharing options...
Nick Posted October 23, 2007 Share Posted October 23, 2007 An update on what the Mine's ones look like. I thought I'd better have a look, whilst I had the tools out today. Nick if you could find anything out about the plaque number 04386 I would be more than grateful. Pics of the plaque below: No problem, will let you know if they have it on file or need more info. Link to comment Share on other sites More sharing options...
