Lucas Posted September 30, 2007 Share Posted September 30, 2007 I have a new front bumper going on and wanted to put on the sticker version of the front number plate. Anyone know where i can get this? Cheers Link to comment Share on other sites More sharing options...
liam1 Posted September 30, 2007 Share Posted September 30, 2007 got mine from a local graphix place im sure most will supply you with one, Link to comment Share on other sites More sharing options...
Flip Posted September 30, 2007 Share Posted September 30, 2007 Got mine off ebay, from someone like this:- http://cgi.ebay.co.uk/SELF-ADHESIVE-CAR-NUMBER-PLATE-STICK-ON-FRONT_W0QQitemZ150131984324QQihZ005QQcategoryZ52638QQrdZ1QQssPageNameZWD1VQQcmdZViewItem As an aside, I have an MOT coming up, do these plates generally get through an MOT? I have a full size plate and normal lettering, its just that its sticky, not a proper one. Link to comment Share on other sites More sharing options...
liam1 Posted September 30, 2007 Share Posted September 30, 2007 im sure all those mx-5s have passed mots most of the ones ive seen are the sticker type. Link to comment Share on other sites More sharing options...
NeoFuture Posted September 30, 2007 Share Posted September 30, 2007 no there not road legal unfortunatly Link to comment Share on other sites More sharing options...
Jamesy Posted September 30, 2007 Share Posted September 30, 2007 Got mine off ebay, from someone like this:- http://cgi.ebay.co.uk/SELF-ADHESIVE-CAR-NUMBER-PLATE-STICK-ON-FRONT_W0QQitemZ150131984324QQihZ005QQcategoryZ52638QQrdZ1QQssPageNameZWD1VQQcmdZViewItem ohhh nice find - i need a front number plate sorted somehow. do u think it'd be ok if i stick this on the bottom part of the Veilside bumper, right at the bottom? dont fancy having it on the bonnet or top of the bumper. (will this stuff stick to the fiberglass bumpers ok?) Link to comment Share on other sites More sharing options...
Jake Posted September 30, 2007 Share Posted September 30, 2007 no there not road legal unfortunatly You're correct that they aren't road legal but wrong that they'll cause you to fail an MoT test. You can pass the MoT test just fine with a stick-on or undersized plate. Link to comment Share on other sites More sharing options...
Ady Posted September 30, 2007 Share Posted September 30, 2007 go to your local stermat theer 29p each and they are all 72mm high and minimal wide dimensions from the dvla point of view I got E16 ADY from there, not got stopped yet - visit the dvla web site,you have to have at least 11 mm gap in between letters, ect ect Link to comment Share on other sites More sharing options...
NeoFuture Posted September 30, 2007 Share Posted September 30, 2007 your plate needs to be visible from a distance and square on pretty much to pass an MOT, you can stick it on the bottom, i have seen them there but there is a chance of getting pulled and you wont get through an MOT unless your tester is very forgiving and a little bit blind Link to comment Share on other sites More sharing options...
NeoFuture Posted September 30, 2007 Share Posted September 30, 2007 You're correct that they aren't road legal but wrong that they'll cause you to fail an MoT test. You can pass the MoT test just fine with a stick-on or undersized plate. i failed an MOT cause of a stuck on plate a few years back (wasnt on a supra) Link to comment Share on other sites More sharing options...
Lucas Posted September 30, 2007 Author Share Posted September 30, 2007 Got mine off ebay, from someone like this:- http://cgi.ebay.co.uk/SELF-ADHESIVE-CAR-NUMBER-PLATE-STICK-ON-FRONT_W0QQitemZ150131984324QQihZ005QQcategoryZ52638QQrdZ1QQssPageNameZWD1VQQcmdZViewItem As an aside, I have an MOT coming up, do these plates generally get through an MOT? I have a full size plate and normal lettering, its just that its sticky, not a proper one. Nice one thanks for that link. and thanks for the advice guys Link to comment Share on other sites More sharing options...
Jake Posted September 30, 2007 Share Posted September 30, 2007 i failed an MOT cause of a stuck on plate a few years back (wasnt on a supra)Not because it was a stick on one. I'm sure the MOT test only checks the spacing or format(layout not font) of the chars Link to comment Share on other sites More sharing options...
NeoFuture Posted September 30, 2007 Share Posted September 30, 2007 Not because it was a stick on one. I'm sure the MOT test only checks the spacing or format(layout not font) of the chars nope mine was all spaced and formated correctly and i still got a fail on the MOT i think the rule of thumb is try it and see can always temp fit a plate, mine was in the same kind of possision at the picture above, they said it was not correctly visible from the road Link to comment Share on other sites More sharing options...
Jamesy Posted September 30, 2007 Share Posted September 30, 2007 will this stick on plate stick to the veilside bumper ok do you know? or does it have to stick onto metal? Link to comment Share on other sites More sharing options...
hadyn Posted September 30, 2007 Share Posted September 30, 2007 Skewer do nice stick on number plates: have a look under 'other graphics': http://www.skewer.co.uk Pic of one of their plates on my mates GT4: Link to comment Share on other sites More sharing options...
hadyn Posted September 30, 2007 Share Posted September 30, 2007 The skewer plates stick on plastic no probs... Link to comment Share on other sites More sharing options...
Jake Posted September 30, 2007 Share Posted September 30, 2007 nope mine was all spaced and formated correctly and i still got a fail on the MOT i think the rule of thumb is try it and see can always temp fit a plate, mine was in the same kind of possision at the picture above, they said it was not correctly visible from the roadSurely there's no 'rule of thumb' in MoT tests. It's either against the rules or isnt. AFAIK there is no rule against stick on plates. Link to comment Share on other sites More sharing options...
hadyn Posted September 30, 2007 Share Posted September 30, 2007 The above GT4 has sailed through an MOT with stick on number plate on. Link to comment Share on other sites More sharing options...
Jamesy Posted September 30, 2007 Share Posted September 30, 2007 Skewer do nice stick on number plates: have a look under 'other graphics': http://www.skewer.co.uk Pic of one of their plates on my mates GT4: i like that size plate ... seems a bit smaller than the ebay one - i have just emailed them Link to comment Share on other sites More sharing options...
vvteye Posted October 1, 2007 Share Posted October 1, 2007 Skewer do nice stick on number plates: have a look under 'other graphics': http://www.skewer.co.uk Pic of one of their plates on my mates GT4: http://img.photobucket.com/albums/v55/hadyn/DSC00207.jpg Bet he wishes he had stuck it on straight Link to comment Share on other sites More sharing options...
Lucas Posted October 1, 2007 Author Share Posted October 1, 2007 Hay did not know about Skewer and they are just down the road from me. Cheers for that. Link to comment Share on other sites More sharing options...
spidermonkey Posted October 1, 2007 Share Posted October 1, 2007 Surely there's no 'rule of thumb' in MoT tests. It's either against the rules or isnt. AFAIK there is no rule against stick on plates. mine has passed for the last 4 or 5 years:) (and its smaller than normal) Link to comment Share on other sites More sharing options...
wile e coyote Posted October 1, 2007 Share Posted October 1, 2007 Mine passes ok , Was told that only problem would be that they are not reflective Link to comment Share on other sites More sharing options...
