Parts needed for 6 speed conversion
Guest mk47
Im under the impression i need the following parts to do a full auto - manual conversion, can people please add or correct where necessary..
1) gearbox of course
2) clutch master/slave cylinders
3) manual flywheel
4) clutch pedal
5) brake pedal
Is that all that is required? auto tt diff/prop shaft would it be ok to use on a 6sp manual?
I've supplied new parts for a few conversions now, if you need anything Maz give me a shout.
I will definately be in touch nic mate. Ive got a 6 speed box now :D need all the rest.
Have a few qs though still, i.e. will my auto diff be ok or does that need changing? also any other advice is appreciated.
