Vibration through car
bibblebob
I have just changed my wheels from 17" to 18" the car was already lowered 35mm but since the change i get a big vibe through the car when i hit about 90mph onwards it only does it with these wheels. They are Ultralite GT2's and are brand new inc tyres and have tryed two sets and get the same problem. Is it possible i need to get the tracking and camber/caster adjusted because of the change in height and wheel size. help
have you got hub centric rings fitted?
the hole in the ultralites may be bigger than the 60.1mm hub on the supra, a disk of alloy should be fitted to fill this gap........do you have them?
No, it'll be a wheel or tyre issue. Maybe balance, but probably lack of concentricity, or the the wheels themselves aren't round. Cheap wheels can be anything BUT round, believe it or not.
:(Thanks for the advice guys but i think it my be the fact that it has cheap fulrun tyres they are balanced perfect and they do have the spigot rings fitted. But it has gone from standard to 18" with 265x35x18 and a 40mm drop(not 35mm) it must need some camber adjustment.
  • 3 months later...
Hi did you ever get this sorted? Im curious as I have the same sized wheels and same branded (might as well be unbranded) tyres and I get a vibration around that sort of speed sometimes!
