Guest RednSilversupra Posted December 5, 2004 Share Posted December 5, 2004 Hello guys, I need some help with figuring out what is wrong with my car...... It started to die on me as soon as i let go the race padle.... first time i put some feul system cleaner wich helped the problem for few days but now it does not hold and idl, as soon as i let go the accelerator it kills..... i just replaced the spark plugs, wires and the dist. cap, that still didnt fix the problem. I wondering if there is anyway to keep the idle up on it or do i have to replace the feul filter????? im just shooting in the dark now....need some help......... Thanks alot Mo Quote Link to comment Share on other sites More sharing options...
keron Posted December 5, 2004 Share Posted December 5, 2004 this happened to me before....it was due to a low oil amount! just double check it! Quote Link to comment Share on other sites More sharing options...
Guest RednSilversupra Posted December 5, 2004 Share Posted December 5, 2004 Thankx for the tip i checked the oil and the level wasnt too low..... i filled it up again anyways. I also wanted to add that my car is blowing alot of black smoke when i start it........ I think i might have started it 8-9 times for few minutes each and it has taken close to 1/4 tank of gas...... it smell like it is running toooo rich.......... Can somebody help me in this situation?????? I am stuck and dont know what to do....... Should i just take it to a mechanic???? How much of bill would i be looking at????? Any help is appreciated......... Thankx MO Quote Link to comment Share on other sites More sharing options...
Tannhauser Posted December 5, 2004 Share Posted December 5, 2004 I just had a similar problem and it turned out that the map sensor hose had come off. Perhaps you could look for leaking or diconnected hoses? Quote Link to comment Share on other sites More sharing options...
Guest RednSilversupra Posted December 5, 2004 Share Posted December 5, 2004 Thank you Tann, Can you please tell me where to find this map hose or the sensor and how to check the sensor? Im sorry i just started working on the car myself, i never had any problems with it before.... it so happens that when im tight on money i get these problems..... i called to find out about the o2 sensor and that is pretty expensive....... I need to get the car back on the road but dont know what to do..... Once again thank you for help..... Mo Quote Link to comment Share on other sites More sharing options...
Tannhauser Posted December 6, 2004 Share Posted December 6, 2004 Well, this could well be the blind leading the blind: best wait for someone cleverer to help. The sensor itself is on the intake plenum I think. But I see you're in the USA so yours might have a MAF sensor - don't know how that alters things if at all. Cliff Quote Link to comment Share on other sites More sharing options...
Terminator Posted December 6, 2004 Share Posted December 6, 2004 Hmmm Dis cap common problem with the TT I had to swap out two new ones faulty from the factory. I think you should change the points and get off at the next station Edit Oops did not think you guys had NA's over there:stupid: Quote Link to comment Share on other sites More sharing options...
Guest RednSilversupra Posted December 7, 2004 Share Posted December 7, 2004 I have changed the plugs and the distributor cap along with the wires...... That didnt do anything..... Need more help!!!!! I have no clue where the MAP is....... Please help!!!!!!!!! its is blowing black smoke at start and then it dies out........ I'll be waitin Thanks alot guys in advance for your assistance in the matter Quote Link to comment Share on other sites More sharing options...
