Duty Cycle
Kev.O
Err?? duty cycle will be anything between 0-100% depending on what the map in the ECU tells them, are you thinking of lag time?
Richard asked me what the duty cycle will be, and as I didn't know I said I would find out. He said that he doubts I'll be running the injectors at 100%.
Ahh right, you need to add them all together and IFAIKR multiply the total by 10%-15% , you will also be better of dividing the required jet size in two, as you will get better atomisation.
http://www.imagestation.com/picture/sraid215/pd412cc22545ed47f6a61f4bc7b65262e/eceb69be.jpg
Oh! and ideally if you have sized the fuel injectors right then you should not see more than 85% DC.
  • 4 weeks later...
So total at 10% is 432 and at 15% is 648. I'm a little uncertain what these figures mean :blush: Could someone pleasae tell me what size injectors I need.
  • 1 month later...
i spoke to richard L today about the two nozzle's being better than one, he said as long as you have the nozzle some distance from the throttle there is no need
saves me taking my headlight out again :)
Did Richard happen to say what the optimum distance from the T/B was? ;)
I read on the aquamist forums that close to TB gives better cylinder cooling, further away provides better charge cooling, it has more time to cool the air.
You could use two 0.5mm jets at different locations if you wanted, I have a single 0.7mm in mine right infront of the throttle, I noticed a nice drop in EGT and the mixture read leaner due to more O2, this was from my AEM datalogs.
If you are working off a pressure switch and have no way of regulating the amount that is injected dont go for the size rated at full boost, if you are injecting at 1bar then work out whats needed from there up.
What are the results then?
Nothing conclusive at the moment, when i first fitted the extra jet, i had mapping problems, i then went straight into the kit fitting and respray, and while i was doing that i put in some bigger injectors, which i am still dialling in, so not had a chance to take any temp data logs that that would make any sense, as everything else is out of whack, plus winter has come along, so i need to take some baseline temp logs first.
  • 1 year later...
Thought I'd post in here rather than start a new thread. I realise I need to fit a restrictor pill, but unsure as to what size, plus I can't find any of them at the moment.
I'm using a 0.8mm jet. The calculations are:
720x0.8x6=3456 then x 10% gives me 345, which is why I've gone for a 0.8mm jet. Can anyone advise me on what size restrictor I should use please. Thanks.
"restrict or pill" :blink: not sure what you're referring to Kev?
I've googled what it was and the guys on the evo site called it a pill :search:
It's the flow restrictor that goes in the 6mm pipe between the pump and the HSV. Well it actually fits in the end of the HSV.
I'm afraid i haven't heard of this, or used it, what is the reason for one? why would you want to restrict the flow,wouldn't that defeat the object.
Its preferred to have an accumulator after the pump to avoid flow variation, the whole system relies on high pressure and good flow rate to achieve a constant injection rate?
I'm honestly not sure, and this could be the reason why I can't find them ie I never had them. I can just remember thinking to myself that I needed to fit the restrictor, but didn't know at the time which one to fit.
