snake Posted September 26, 2007 Share Posted September 26, 2007 mine arrived today blitz md boost gauge as i cant understand japanese i am trying to find out what the wiring is any help would be appreciated:search: Link to comment Share on other sites More sharing options...
rovervi Posted September 26, 2007 Author Share Posted September 26, 2007 Great help thanks I got mine through a former trader on the forum, but he no longer trades here. AFAIK there isn't a UK distributor for the STRI DSD range but they're based in the Netherlands http://www.stri-racing.com/. I had a problem with a faulty gauge when supplied and they replaced it foc even though I hadn't dealt with them direct. The guy I deal with was Ton and he can be contacted on [email protected] HTH Link to comment Share on other sites More sharing options...
Guest DaveWilko Posted September 26, 2007 Share Posted September 26, 2007 around - 0.8 Thanks Ric. I thought so. When I switch on the ignition The needle flicks round to the stop and then settles at -0.4. I imagine it should sit at 0. Then at idle it is off the clock at about -1.1. Going to try dismantling the guage and reposition the needle:blink: Link to comment Share on other sites More sharing options...
Pabs Posted October 1, 2007 Share Posted October 1, 2007 For those with the Defi DIN Gauge: Am i right in assuming the scales on each dial on the defi website are the only scales available? I'm researching into this, and it seems that the boost isn't in bar/psi, and the temps are in degrees F rather than Centigrade..... I suppose if this is the case then I'd make my own "DIN Gauge" using 3 52mm Defi gauges in a facia from ebay or whatever. Will cost more, but at least you can choose your gauges and scales. Link to comment Share on other sites More sharing options...
Kev.O Posted October 1, 2007 Share Posted October 1, 2007 mine arrived today blitz md boost gauge as i cant understand japanese i am trying to find out what the wiring is any help would be appreciated:search: Did you get this sorted matey? Link to comment Share on other sites More sharing options...
