Chris Wilson Posted September 25, 2007 Share Posted September 25, 2007 I managed to stick a rod through the block on my RB25 engine in my Skyline, at the then new Anglesey circuit, a few months back. The car came back on the end of a rope and was pushed, in disgrace, into a corner, and left to fester. I am now taking a bit of time out to pull the engine and have a look what happened. Lots of revs and ignoring how many hours on track the thing had done are the generic cause, it should have had a refresh ages before the "bang". I suspect rod bolt failure to be the actual cause, we'll see. I'll post pictures. I hope to replace it with a new RB26 engine which has been in build for about 2 years and still isn't finished.. The incentive to get on with it has now arrived! Quote Link to comment Share on other sites More sharing options...
Guest Chumpalot Posted September 25, 2007 Share Posted September 25, 2007 What are the differences between the RB25 and RB26 engines Chris? Excuse the n00bish question, just trying to educate myself tis all. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted September 25, 2007 Share Posted September 25, 2007 What spec will the RB26 be Chris? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 25, 2007 Author Share Posted September 25, 2007 RB25 is 2.5 litre, weaker rods, but shorter stroke, single throttle body, rather than 6 throttles, more basic plenum, hydraulic cams, single turbo, blah blah. A good engine, but not as sophisticated as the RB26, which is in 4 wd Skylines. Mine is just a 2wd one, as it's lighter, more fun, and easier to work on (and cheaper..). Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 25, 2007 Author Share Posted September 25, 2007 What spec will the RB26 be Chris? Quite decent. All steel (crank and rods) very trick FORGED pistons, but with hollow crowns for oil cooling, 280 degree cams with 11mm lift, oversized throttle bodies, fully worked head, Motec M800, light flywheel and clutch, blah blah. Can't decide on turbo set up, probably twin, but maybe a single. looking for a track reliable 600 HP max, with great torque and quick spool. I think there are still photos of the early part of the build and the bits in it at ftp://ftp.chriswilson.tv/skyline_stuff Something like race engine build folder, or similar. Quote Link to comment Share on other sites More sharing options...
JohnA Posted September 25, 2007 Share Posted September 25, 2007 Chris, If you were to fit 6 throttle bodies on the RB25, would you expect any marked improvement? Has anyone done it? (my gut feeling is 'no', but lots of people think otherwise) Quote Link to comment Share on other sites More sharing options...
Pete Posted September 25, 2007 Share Posted September 25, 2007 ..and there was me thinking you were going to put the newly repaired Matiz engine into it. Quote Link to comment Share on other sites More sharing options...
Tom Posted September 25, 2007 Share Posted September 25, 2007 I love the skyline I have right now, I even prefer it to the supra in a lot of ways keep us updated Chris, should be nice to see Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted September 25, 2007 Share Posted September 25, 2007 Lovely spec Best of luck with it. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 25, 2007 Author Share Posted September 25, 2007 Chris, If you were to fit 6 throttle bodies on the RB25, would you expect any marked improvement? Has anyone done it? (my gut feeling is 'no', but lots of people think otherwise) With fairly long duration cams (much longer than the stock hydraulic ones) you would get a marked improvement in throttle response, but top end power would remain similar. It would take a fairly sophisticated ecu to make the best of it (dual mapping or better capability). People tend to jump to the RB26 rather than spend a lot on the RB25. Mine makes about 460 flywheel BHP with very basic mods. Quote Link to comment Share on other sites More sharing options...
steb9780 Posted September 25, 2007 Share Posted September 25, 2007 What were those throttle bodies I opened up for you, ages ago, for Chris? Where they for your car?? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 25, 2007 Author Share Posted September 25, 2007 What were those throttle bodies I opened up for you, ages ago, for Chris? Where they for your car?? They were, yes, and very nicely done done they are, too Quote Link to comment Share on other sites More sharing options...
steb9780 Posted September 25, 2007 Share Posted September 25, 2007 They were, yes, and very nicely done done they are, too So does the RB25 run individual throttle bodies, or are they for the RB26?? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 25, 2007 Author Share Posted September 25, 2007 They are going on the RB26, I have pics of them next to stock ones at: ftp://ftp.chriswilson.tv/Skyline_Stuff/RB26_Race_engine_Pics/next I had them flow tested on the new head, after the porting was done, and the manifold and plenum matched to them, and they made quite difference, comapred to the stock bodies. Quote Link to comment Share on other sites More sharing options...
JohnA Posted September 26, 2007 Share Posted September 26, 2007 Chris, are they fit-and-forget (ish) or do you need to synchronise them then and again? Quote Link to comment Share on other sites More sharing options...
steb9780 Posted September 26, 2007 Share Posted September 26, 2007 They are going on the RB26, I have pics of them next to stock ones at: ftp://ftp.chriswilson.tv/Skyline_Stuff/RB26_Race_engine_Pics/next I had them flow tested on the new head, after the porting was done, and the manifold and plenum matched to them, and they made quite difference, comapred to the stock bodies. Yes I can imagine as they were opened up by quite a bit. They must flow quite a bit more air. My eyes nearly popped out of my head when Mark told me how much to take out of them. I got a bit worried when all the tapped holes and take-offs started to break through, but he'd already warned me of what I was about to witness Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 26, 2007 Author Share Posted September 26, 2007 Stock ones stay in synch just fine, will let you know re the 50 mm ones Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 1, 2007 Author Share Posted October 1, 2007 Engines out today, will get some photos, but apart from the big `ole in the block I found the causes of the low boost, a warped turbo flange and blown turbo gasket, and a split in the underside of the flexi hose from the turbo compressor outlet to the I/C hard pipe. It was mainly hidden by the Jubilee clip. The car has wanted for attention for months, but just got thrashed instead, so it's no surprise the thing has issues. I have decided to build the new engine on ported, but otherwise stock cast iron manifolds, i have had nothing buy aggravation with this Apexi single turbo manifold, and the IHI turbo, which has warped its flange three times now. Quite why they decided M8 studs were adequate to hold the thing on, I don't know. It's things like blowing gaskets and warped flanges that REALLY do my head in with these aftermarket turbo kits, I'll happily accept the added complication of twin water cooled GT2860-5's if the things work reliably! A mouse has been lodging in the coil valley, too, and eaten the coil pack loom, so to top it all I have had squatters... Quote Link to comment Share on other sites More sharing options...
Bob Posted October 2, 2007 Share Posted October 2, 2007 Speak to Jazz1 re: the rodents, I'm sure he could offer some helpful advice Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 3, 2007 Author Share Posted October 3, 2007 Engine is now partly stripped and it's a proper job, as I suspected. Rod bolt failure, the rod then lathed through the crank main bearing girdle, poked a hole in the block, and the main oil gallery. The pistons eaten a bit of the head and bent two valves, probably breaking the guides, too. Sump is knackered, so is the crank. Glad it was only a fairly stock thing! http://www.gatesgarth.com/bang/bang.html How do you load up pictures WITHIN the forum post, like Wayney did with his exploits abroad? Quote Link to comment Share on other sites More sharing options...
Ady Posted October 3, 2007 Share Posted October 3, 2007 You should have told me you were there man !!!! I only live 15 mins from it haha Gutted about the dammage mate Quote Link to comment Share on other sites More sharing options...
Thorin Posted October 3, 2007 Share Posted October 3, 2007 How do you load up pictures WITHIN the forum post, like Wayney did with his exploits abroad? Put [ IMG ]http://www.gatesgarth.com/bang/DSC04209.JPG[ /IMG ] around the path to the images (without the extra spaces between the square brackets). Or in the advanced reply screen click the button and paste in the path to the image. Like so... Quote Link to comment Share on other sites More sharing options...
ivan Posted October 3, 2007 Share Posted October 3, 2007 How do you load up pictures WITHIN the forum post, like Wayney did with his exploits abroad?You wrap the URL of the picture in and tags Chris. Edit: Too slow. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 3, 2007 Author Share Posted October 3, 2007 Thanks Michael, I'll get the hang of this one day I'll try it: Quote Link to comment Share on other sites More sharing options...
Bob Posted October 3, 2007 Share Posted October 3, 2007 Well done Chris, see you can teach an old dog new tricks That's not gonna be a patch weld job to repair is it! lol Quote Link to comment Share on other sites More sharing options...
