My T61 and Airbox Pics
Gaz6002
  • Replies 55
No heat shielding as such (other than the metal) but would be interested to see what you have used.
It was some heat insulation for laminate flooring that i have left over it has a rubber lower face with an aluminised heat barrier.
I just glued it in to place.
Edit. I can cut a piece for you if you like, let me know the dimensions you need and i will see if i have enough.
Do you have a link for the heat insulating you are refering to, i can source th usual motorsport stuff but wouldnt mind a look at this.
James
Hi James
I don't have any info im afraid. it is just the stuff that came with some laminate flooring, B&Q or similar will have it i expect.
