Andrew Posted June 13, 2002 Share Posted June 13, 2002 Anyone know what the tyre pressure should be on the front? I think either my wheels need balancing or the tyre pressure is wrong. I have tyre wear on the outside edge of my right front, I take it the outside wearing is due to under inflation. The problem I have is the sup is a J-spec but it has 17' UK spec wheels, so the pressure could possibly be different. Link to comment Share on other sites More sharing options...
Neil Sandham Posted June 13, 2002 Share Posted June 13, 2002 mines a uk so I have 17inchers. I set them to 36psi as per the sticker on the inside of the door pillar. cheers Neil. Link to comment Share on other sites More sharing options...
Bradb Posted June 13, 2002 Share Posted June 13, 2002 I got a jspec with shirt liftery j-spec wheels. 34 rear, 33 front. nice and even.. I've trialed and errored over the last couple of years. Link to comment Share on other sites More sharing options...
Andrew Posted June 13, 2002 Author Share Posted June 13, 2002 Thanks Neil, do you know off hand what the pressure should be on the back? Bradb do you live near the Japanese Import Centre? You can sometimes pick up 17' wheels they take off the resent imports. When I was there last they sold a set to a guy for £50. Link to comment Share on other sites More sharing options...
Bradb Posted June 13, 2002 Share Posted June 13, 2002 Seriously Andy. Geez, I'd be down there like a shot. I'll have a bowl of that. Whats there number. Cheers, Link to comment Share on other sites More sharing options...
Guest Martin F Posted June 13, 2002 Share Posted June 13, 2002 Jesus 17' wheels, they must be real monsters. The 16" ones are usually £50 a set, but the 17" ones go for nearer £300. Link to comment Share on other sites More sharing options...
Bradb Posted June 13, 2002 Share Posted June 13, 2002 I don't give a monkeys. I want UK Spec wheels. Do me just dandy. Has anyone on here got any they want shut of? Link to comment Share on other sites More sharing options...
Andrew Posted June 13, 2002 Author Share Posted June 13, 2002 JIC's number is 01883-744439 Worth a try. As Martin says they must have been monsters, or I've got it wrong and they were 16' Link to comment Share on other sites More sharing options...
Myles Posted June 13, 2002 Share Posted June 13, 2002 Originally posted by Martin F the 17" ones go for nearer £300. ...err , I think Eyefi might be selling some 17"s Link to comment Share on other sites More sharing options...
Bradb Posted June 13, 2002 Share Posted June 13, 2002 Coo. Eyefi? [email protected] Link to comment Share on other sites More sharing options...
Neil Sandham Posted June 13, 2002 Share Posted June 13, 2002 Both front and back are 36 psi for the uk 17 inchers. Cheers Neil Link to comment Share on other sites More sharing options...
Terminator Posted June 13, 2002 Share Posted June 13, 2002 MKIV's tend to wear on the inside, if you are wearing on the outside , it might be alignment rather than pressure. 35 front and 34 rear is a good compination, even wear if alignment is spot on. Link to comment Share on other sites More sharing options...
Andrew Posted June 14, 2002 Author Share Posted June 14, 2002 Cheers Neal. Looks like your right Term the alignment must be out, as the tyre pressure on the worn tyre was spot on 36psi. Link to comment Share on other sites More sharing options...
AJI Posted June 15, 2002 Share Posted June 15, 2002 Sounds like a wheel tracking issue rather than inflation.... you probably have a bit too much toe-out on the front. A couple of months ago I had a bit too much toe-in and it was wearing away the inside tread like a bugger. It made for real sharp cornering but it had to be sorted or else I'd end up with slicks. If its was under inflation then you'd be wearing both inside and outside tread at the same time. Over inflation wears away the middle tread. Link to comment Share on other sites More sharing options...
