SQL 2005 Deleted Builtin\Administrator group now can’t login
caliAl
As the title says I stupidly deleted the Builtin\Administrator group now can’t loginin SQL Server 2005. Is there anyway get back in?
I did not setup the server up so I’m unsure what the SA password is. As a last resort could I rebuild the Master database and then over write with backup?
Thanks,
Alan
On the server itself... you should have an NT group with a name like this:
[servername]\SQLServer2005MSSQLUser[servername]$MSSQLSERVER
This user group has SA rights within SQL. Add yourself to this group and then you should be able to get access.
The other option is, that generally speaking, as a standard most place will change the sql services to run as domain accounts, try using that.
Technically speaking that group should be removed, once you have setup the security correctly!
Hope this helps! :D
